M
mouser
Guest
Hello I'm new on here and was wondering if anyone can advise me of the correct procedure for removing the nut which holds on the drum. The car is a 1.0 Micra 1999. In particular whether the threads are normal or opposite for the passenger side as is the case on some Fords I have worked on. The nuts themselves have a small collar around the end which has been bent into a groove in the shaft. Is there a method for straightening this out or is brute force the answer? I did not want to force anything at this stage and would appreciate any guidence given.
Many thanks,
Mouser.
Many thanks,
Mouser.
