new discs and pads fitted :) but..
So long as the pads will slide freely its most likely a piston is sticking Loen.
Try freeing it off.......... take the caliper off, take the pad nearest the piston out, press the brake pedal slowly but jam a bit of wood or something to stop the piston going all the way out!
Do this a few times & if its not free'd you'd be best to refurb the caliper, this is best done in pairs as well :)
If this was on new disc's as well going blue has probably warped them so might need replacing as well!
i have had a look at the disc it dosnt look warped i will check again tomorro, i think i may have freeed it off, i will take for a test drive tomorro, see how it gose!:)
okay, well ibll test it tomorro , and buy a new disc , it got so hot, that my wheel nuts couldnt be touched :(, burn me :/
If the caliper and pads are free, and you're scratching your head it could be this.
I've seen the flexible hose collapse internally and work like a one-way valve keeping the pressure at the caliper.
ive seen this at work and can be a right pita :/
no i dont have that gauge will get a garahe to check, and i noticed when i redune the pads at like 7pm, there really tight, :/,
When the pads are new and thick the sliders in the calliper carrier are at their shortest (pushed right in.) They can stick there. Loosen the two 12mm bolts about 5 turns and make sure you can still push the slider outwards, away from the car, ie into the calliper carrier.
i got them working now :),the only thing i saw was the lil springy bits on the calliper carrier 1had seezed so pulled it out and regressed it and everything working fine now :)
thats why i change 1 pad at a time leon, it holds the springy bit in place :)
i see frank haha, i didnt know this :p i do now tho :)it was seezed to a bi##h anyway propper corrodied so needed soring out :), all good now :)and the disc isnt warped witch is a bonus :), still gatta find out whats wrong with my car :(
