wiring diagram
Does anyone have a wiring diagram for the ST? The injectors aren't getting any signal. I was also wandering if the voltage for the inj comes from the ecu? I know they are fired by an earth sig.
Pm me your email address an I'll send it to you
Hey Baz,I`m new to the club but have been following up for quite a while,have a K10 with the MA10ET engine and I get a flat spot when I move off then the turbo kicks in,what do you think could be the cause do I need a fuel regulator or something??
Could be anything, wouldnt know unless I seen the car. The standard fuel reg should be ok
