what size are threads of engine
Paul Smith
Site Supporter
Basically i am after a oil pressure T piece but i need to know what size thread the cg13 engine uses so i get the right size?
How do you measure this?
Paul
its none of these.. its 1.8thBSP tapered. remember its a tapered fit or you could crack your block fitting it in.
you say your using the a feed from the oil pressure switch, let me know how you get on as i used this and have now went back to the plug on the front of the head.
