what clutch?
Shero
So the clutch is slipping away on the superS so time for new one i think.
Ive never done a clutch before btw, so tips advice is welcome/neeeded :D.
http://cgi.ebay.co.uk/NISSAN-MICRA-...arts_Vehicles_CarParts_SM?hash=item4837868bec
Can i use that clutch on a cg13 even though its for a 1.0, because many of them others say they are for 1.0 - 1.3s?
If not which should i go for from the bay?
http://shop.ebay.co.uk/?_from=R40&_...kw=micra+k11+clutch&_sacat=See-All-Categories
And... is there anythin specific to look out for when im doing it, ive read through the haynes bit, but just incase he left any bits out regarding really hard bits that they always do. " simply loosen the nut" forgeting they done it on a brand new micra and mines had years or abuse and corrosion. lol :D
cheers micra fans!(Y)
that looks like the pre98 1.0 one (which is smaller) and i prefer luk/nissan ones personally because the diaphram is made from thicker spring steel (my exedy one slipped at about 90hp)
and its a pretty straight forward job to lower the g/box down :)
cheers frank, well im buiding the car up to hopefully a good bit beyond 90hp, so a stock one wont be that good thinking of what it can cope with....
So the 4 paddle rally one http://cgi.ebay.co.uk/NISSAN-MICRA-...arts_Vehicles_CarParts_SM?hash=item3a50b1ce2d
or the helix one off rally nuts http://rallynuts.com/motorsport/K11_Tuning_2084/Helix_Racing_Clutch_Kit_Nissan_Micra_K11_3161.asp ??? any prefrencesor good bad points you know about??? ive heard that the 4paddle ones are pretty bad for road use???
cheers.
no, my exedy one is a pre98 1.0 one, and my same size luk one has,nt slipped yet at over 100hp.
(the post98 1.0)/1.3/1.4 (bigger) clutches will take 150hp ish :)
ahhh i see, well i think im gunna grab a spare cg13 and swap it while i build this one up.
this guy just makes it look a pretty simple job.
http://www.youtube.com/watch?v=6BaECAbapRg
lol. im sure ill take more than 3 minits for mine. :D
Also, have you used or had experience with this lightend flywheel. ive found this one for 255 before shipping but is there anywhere else that i can get one from.?
just hunting for the luk one to have a look at... :D
i could lighten you a cg13 fly, and get it somewhere near the weight of the one above, would be a cheaper option too.
k6pfs ...im getting the helix clutch off matt humphris, will that flywheel match up to that ok?
and superls, how much you talikng for thelightend stock cg13 fly??
Cheers.
