What brakes do you use
Anyone run 4 pot calipers and disc on the back. There is a wildwood kit on eBay for a Nissan sunny does anyone know if they fit and are they any good.
Nissan Sunny N15 1.4 Calipers & Vented discs on the front, cheap and easy mod. For anything apart from tarmac stage events we run EBC Black pads, will be trying EBC Yellows on the upcoming stage rally.
Rears, standard K11 Micra rear disc conversion kit, as fitted by Matt Humphris, with hyd. handbrake and bias valve. Running EBC Black pads for all events
Depending on the type of event, I also run brake cooling ducting for the front and rear.
So do you run 13" wheels with the sunny calipers or 14". I want to stay on 13 but my current set up is not ideal brake are getting to hot. I thinking of buying rear calipers with the hand brake cable type and some ebay item 381078564167.
