turbo injectors
Stock injectors are wide open at around 105-110bhp NA. Even GA16's are pulling around the 70% duty range at that level so they fall well short for a CG13 turbo.
The only scope for drop in solutions are going to be if you go for a top feed rail from the coilpack engines.
Just to clarify they are working but having just double checked some of the old emanage logs there's not a lot of wiggle room and tbh i'd put something bigger in just to be safe.
A fuel pressure tweak can help compensate, but if you're upgrading anyway you may as well go the whole way :)
Cga rail on sr20det 317cc injectors??
Wont be having it mapped for awhile so need some good injectors
Any problems fitting the cga rail on the cg13??
Ga16 throttle body is a direct replacement isn't it frank? Would this solve the problem?
Guessing cga rail fits easy then direct replacement
