Turbo ideas/help
Haven't you briefly hit 20psi before Paul?
u mean when my actuator hose ruptured - unaware of losing boost control - whilst overtaking at full boost - and the silicone pipes popping apart at very high boost - losing all power whilst beside a slow lorry with oncoming traffic getting closer - almost shatting pants, moment?... probably, but was very brief
ok frank readings I got are:
-21psi at idle
-24psi at 3k in neutral
-14psi cruising at 3k/70mph in 5th
10psi from 2.8k in gear
10psi from 5k in neutral
-21psi at idle
just shows the difference from bigger and smaller turbo,s eh paul, mine builds hardly any boost in 1st gear, and i can watch the boost needle drop if i spin the wheels in 2nd (ghetto traction control :))
thats a high boost threshold.
my pressure switch boost controller may also be contributing to the reduced threshold point by keeping that WG fully shut till it see's 10psi.
