Throttle body gasket?
M
mudfly9
Guest
I've just performed the throttle body re-soldering trick on my 1.0l K11 and all now seems well. However, I bought a Haynes for it today and it mentions a main throttle body gasket that didn't appear to be on mine. Should I have one? Can I just make one out of paper?
Thanks in advance.
it should have a little gasket :S u sure its not stuck to your inlet manifold or tb? if not u need to get one from nissan really
Yeh, I definitely took it off. In retrospect I don't suppose I really needed to for re-soldering though it gave me chance to give the butterfly valve a good clean. Will probably try and make some kind of gasket as there seems to be an ever-so-slight hesitation in accelerating sometimes, though it could just be me imagining it as I find it difficult to believe that re-soldering ok-looking joints will fix the problem. It's just too simple! Thanks for the advice guys.
