CMF_Tyrie
» CMF Member
as above, you need rim specs not tyre specs. Those tyres will fit no worries as long as the rims are suitable. Something in the region of 15x6-15x7 with an offset of +35 +40 should be fine
CMF_matt.d
» CMF Member
give me a discription of what you mean off set +35 +40 i put the rims on and they fit fine handles like a dream now so ive no need to mess with suspension. Problem is there only on about a millimetre around the centre hub is this a problem for me apparently they came off a micra k11 same as mine im just going with how the steel 14 inch rims fitted before thought the alloys would fit like a glove the same
