Tailgate handle rubber seal, Micra K11 Mk2, 2002
I noticed the tailgate handle was loose on my k11 (in UK) as shown in photos. When i took it off i found the rubber seal around the top was perished and hanging off. Whats it called, T-profile seal strip? Ive posted a picture of the end profile of the rubber that came out, it had glue on 1 side originally i think.
Has anyone found anything to put around here to seal it and hold handle firm again? I found second hand seals for crazy money on ebay, but im sure something a lot cheaper like U profile rubber would do the trick? I've tried P profile draught excluder but its not sealing.
Could use silicone sealant i guess, but it would look a mess. Got water leaking into the spare wheel well now.
Any suggestions welcome.
Thank you.
I have bought some T-type 7 x 5mm rubber strip, I will let you know how it works when i get it. It will leave a 5mm black rubber strip showing around the top of the handle, but if it stops water getting into the boot it'll do.
Thank you.
Try the company below, you might be able to match it up?
I have applied the T shaped rubber seal and it is all good as new. It was a bit tricky to get the rubber to go over the edge pf the handle esp around corners, but used a thin piece of flat plastix to pop if over the edge.
Here are pics of the seal, just like new.
