Super S Alternative Engines?
Hi Guys,
Looking For An Alternative Engine For My Super S.
I've Been Told The Figaro Engine Fits And Also The SR20 DET Engine.
Are There And Others And Which One Is Easiest To Fit?
Regards,
Rob.
fig would be easiest sr20 is pretty much all custom work. the sr20 from a 200sx will not bolt up to the front wheel drive gear box so you will need one from a pulsar. then to fit it into a micra its all custom work not worth it really cause you will have to spend on chassis mods and brakes suspension ect.
why a bigger engine? go turbo!! easiest engine to fit is a ga16 with not much custom work and most things plug and play. weight of the engine alone is maybe not worth it though
a guy from manchester rang me a few hours after and said somone was bidding on his account and he want to come and have a 'look' i said ok ring again when you want to come and hasn't rang since, plus his feedback seems very dodgy
Buy my cbr 600 carbs and unleash a wave of power! Litterally 100s of bhps**
**nb probably more like 20 ;) could be more not sure:D
