Ian said:Its totally different to a turbo mate. 0 lag because its boosting from idle since its driven from the crank. It won't see as much top end power as a turbo but it will produce more torque lower down then a turbo. And it makes a hell of a difference to a car. Unlike a turbo you dont need to gain RPM's and wait for it to spoon, then get more power and keep the revs up to go fast. On a decent set up S/C you juts plant the loud pedal and the torque pulls you a along. it's basically like dropping a larger engine into the car![]()
James said:Type-R if you don't mind me asking, how much is the S/C now? And also how much did you spend getting it all setup? It's one of my plans for next year when i've finished N/A tuning...![]()
Type-R said:mine cost me £300 for SC intercooler plumbing rubbers and loads of other bits and bobs etc etc fabrication. The rest i did myself.
Ed said:Nice.. all except for the retarding the ignition, thats BAD but your correcting that with the e-manage which is ideal. People must remember that retarding the ignition via the distributor also messes up ALL the base engine timing for the injectors etc. Its not something you really want to do.
I may have some developments with the mini SC and the K11 in a few months. This thread has spurred me on somewhat.
Ed
Alienfish360 said:I'd say it would be more difficult to supercharge than to turbo. You have the issue of having to make sure all pullies are straight on it to start with![]()
Retepetsir said:Good luck with the quest.......
I have a question for Ed, are you going to reconnect your SC or just keep it bypassed? Yes you are now running uber power with just the turbo, but 'surely' you'll get better low down acceleration/starts, etc from using the SC too?![]()
Type-R said:i was going to turb's my k11 whilst i was SC'n but then it would just blow up like these k10s do i didnt do it.
