True but it is under extreme vac?
But is it? The turbo in a drawthrough doesnt 'drag' the mixture through the carb does it?
how would i know if pooling occurs?
It can do. They work under atmospheric pressure fuel push. A turbo gives you vacuum pull.But is it? The turbo in a drawthrough doesnt 'drag' the mixture through the carb does it?
As you climb rpm on na the 'scavenge' effect draws air in at a constant increasing rate iirc
Boosted engines draw air at a higher rate as boost increases. Creating a vacuum pull![]()
You'll have to inspect the turbo compressorhow would i know if pooling occurs?
Mine too man mine too. I dont do explaining thingsOk, that makes sense to me, though my head is starting to hurt...![]()
Not too big I'll find one you can use as referencedont be sorry its great to have somebody to tell me all this ! swirl tank it is with this ideait doesnt seem like too much work , how big should it be? ( no immature responces please
lol )
Wouldn't worry about mechanics.. no cars anymore just computers... I love my old cars
Your more knowledgeable than you think ade
Old cars ruleI miss the simplicity of the K10. Everyone thinks I'm crazy cos I get excited at old cars and think most new cars are meh!![]()
Ade from what i see you know a lot , plus , im 18 and i see no attraction to all my friends golfs , bmws and civics , no ECU all the way![]()
The small nipple should be at the bottom.
The bottom pipe is in
The top pipe is out
Bottom should be a bowl shape. Not too big at the top
When I was first told by an old boy I thought he was having me on. The inside of those things aren't smooth so they cause turbulence which in turn atomises fuel.Sorry but I'm yet to be convinced![]()
With the air not being cooled it'll be a tad warm especially so close to exhaust
Never said you have toOk, but I'm still not gonna fit a swirl pot when I build mineCheap and simple.....like me
I think it's purely down to the fact that most cars are fuel injected tbh.Good point ! Just wonder why more dont go for this set up in that case ! Better not think about this too much or might get second thoughts![]()
No i dont believeDo you believe for one second with the research I've done in this that I haven't checked out you tube?![]()
Do it... do it now
Have you seen this before ? No ,Just seen the vid, it just begs the question....why?![]()
