solarice
As the cars getting ever closer to being finished, I figured id give a run down of what I’ve been up to. The car was took off the road earlier this year and has been systematically dismantled over the past few months.
During the dismantling the reason for poor drivability was fairly evident from the oil that had found its way into the gearbox, which wasn’t much of a surprise as at times you could watch it running (not drips, a virtual constant flow) out the bottom as the car was idling.
Since that time it’s had a new front end and sills fitted as well as new fuel lines and brake lines to get it in a high standard condition for the project…with a replacement engine and gearbox available its getting time to put it all back together.
It’ll be good to get the new engine in after all this time, as the rebuild will be truly on…plus on start up I’ll be able to see what difference the new lightweight flywheel actually makes.
Ive got more pics of different things (brakes, plus boxes of stuff
etc) but i'll drip feed these as the rebuild goes on as id rather show them on the car (even if its a mockup), instead of boxed...
