size of front brake banjo bolt and rear brake drum bleed screw?
I need to replace both front brake hoses for MOT as the ferrules are badly corroded and the rear bleed screws need replaced. I'm guessing the banjo bolt is m10 x 1.0mm and the rear brake drum bleeder screw is m8 x 1.25mm. Can anyone confirm?
update: running out of time before MOT, so ordered m10x1 banjo bolt and m7x1 rear brake drum bleeder (this is the micra k12 size hopefully the same as k11).
I've never known that to be an MOT failure. Corroded pipes yes but not the banjos or bleed screws unless they leak.
Sent from my Nexus 5X using Tapatalk
It's just the brake hose ferrules I'm worried about. I bled the brakes a few years ago and the bleed screws were pretty rusted, so I want to replace them (if I can get them to come off). Also, the banjo bolts might get damaged when I take them off so I want some new ones for a backup.
