should i of change the fuel rail and injectors when i swapped from cg10 to cg13? :/
as above really :/, coz ive changed the coolent sensor and now the temp gauge moves haha but not as high as it should be :/ and thats why i thought i was running rich :/, but its still running really rich :/and struggles to start when warm, but strats first time when left overnight :/, help please :) cheeeeerrrrrrssss :)
I checked the part numbers on the injectors whe. I swapped mine and the 1.0l and the 1.4 injectors wer the same
the temp gauge sensor is a different one to the ecu temp sensor leon
right frank what temp sensor do i have to change? :/and i shall change my thermo stat to :), also is bluee smoke outta my exhaust bad? :)
the 19mm (2 wire ) one mate, and blue smoke is usually an oil control ring problem
so when i change that sensor over temp gauge will work find and will that solve the overfueling?, and i think i might have to much oil in it tho :/will drain asap and re fill :)
