Seat fitting??
lee k0011
I hate rust :(
Where can i get a sub frame to fit a bucket seat in to a micra??
Got this today so wont to get it in the car with out spending to much !!
I modified my original rails to take bucket seats
I did the same to mine, just welded on some new brackets to line up with the mounting holes on the bucket seats, and they fitted straight in. Took a few hours to get both seats fitted :)
Sounds like thats wot i need to do then.. I really need to learn to weld could get so much more done with the car then..
I used Mini subframes with a custom floor mounting point for the front so it's tilt adjustable just like on Minis. Bolted the rear straight down onto the floor.
Seat sits about 3 inches lower than the standard one which was a bit of a shock but a lower center of gravity makes it much nicer to drive like that.
There are many ways to achieve this. I took the least cost effective route and used K11 Bride seat rails with Sparco mounts for the Evos.
Modding the existing frames will probably be the cheapest option.....
