The trailing arm brackets, panhard rod mount, and axle chassis mounts are all dangerously corroded.
They must have put tons of salt on the roads during the last Scottish winter. Plus the bushes rubbing
on the metal made them thinner. I asked my local garage if they would weld it up and they refused
as it would not be strong enough. Also, MOT rules indicate that repairs to highly stress components
are unacceptable. I may be able to remove the trailing arm brackets and make new ones, but the
problem is getting a strong weld that will pass the MOT. Plus, the other mounts would need to be
cut out and somehow reconstructed. Not a job I can without a workshop as it would mean removing
the axle and petrol tank and seats. But I'm getting a K13, so my days with micras are not over.
