Running after key is removed?
video doesnt work.. If its a diesel then id be very worried as its not running on the diesel but on the oil, due to overfilling of the oil. If its a petrol then its over run.
uses NATS to keep car secure too ;) if the key isn't on you, it won't run :)
Drawing some schematics and other diagrams up this weekend for it :)
Fordy said:
try a need ignition switch, its on the back of the key barrel its held in by 2 screws
1 screw actually :p at the top :)
Alienfish360 said:
aha! found what was wrong, well right even!
Who needs a key ;) well I do, as long as it's on me when I start it :) if it's not, the car doesn't start :p
http://www.alienfishdesign.co.uk/haha.avi
i hope you followed my guide on hotwiring a micra ;)
it's so much fun starting your car by a button :D unfortunaly its fun for chavs too :(
nope didn't follow your guide. I hope you used relays though ;) or heavy duty switches :)
and fortunately chavs can't start mine :p you still need the nats transponder on your person, within range of the NATS sensor, which is due to be relocated. NATS finally useful for something!
yep heavy duty switches that plugged straight in where the ingition barrel used to be. the only one that isn't sooo heavy duty is the start button but because it is only pushed for a second it doesn't have time to melt :D
have you seen the video of my setup?
http://www.micra.org.uk/attachment.php?attachmentid=4052&d=1146775385
lol i was so scared when i was watching phil solder and burn himself ! lol youve done a good job there tho phil, was nice to see it working in the flesh :D
the one you haven't used a heavy duty switch on, is the one that has a 30amp fuse ;)
I've just used 2 40amp relays :p
lucky i have a fire extiguisher in the car then lol ;)
