Removing rear bumper and jack position
maddave
Club Member (Trial)
Hi,
My gf's 1.0 1999 K11 needs to have a little bit of welding done on the rear. It looks like the previous owner had a bump and the bumper has split its mounting point and water is getting in. I notice two small bolts either side o of the rear boot wall, which look like they hold the bumper on, are these the only things that need undoing to remove it?
Also where does the jack get stored? The car has a nissan scissor jack buut it doesn't sit under the spare wheel and kinda gets squished between the edge of the wheel and the rear boot wall. There is a factory cutout on the boot floor carpet which allows the jack to poke out but it looks a bit ugly. Is this really where its meant to go?
Thanks for the help.
Dave.
there should be somemore bolts under the bumper, you can get to them by lieing underneath the rear of the car.
as for the jack, yes it sits on the left side were the carpet is cut out. just jack the jack the jack up to the wall so its stable. and sits still.
and one bolt into the top corners of the bumper into the rear quarter.
it sits on the right of the boot, at the back, upright under the lip thingy.
