Rear Window not demisting ??
Ive replaced the fuse but on the dashboard the button for the rear window demister to stop it steaming up isnt lighting up, ive replaced the fuse but to no avail. What is the likely problem, ive checked connectors on rear window and they look ok.
Any tips appreciated :)
it maybe the switch itself or a break in the wire some where. you will need check if power is coming to the switch with a multimeter.
ill put a pint of beer on it being the wires between the boot and the car itself - operating the boot open and closed breaks the wires here!
ive fixed many because of it!
i did a rover 25 about 2 weeks ago because of it :)
Check the flexible boot between the bootlid and the car, mine broke TWO wires inside this. One for the Rear no plate lamps, and one for the demister. Use a couple of heatshrink connectors to fix them
