I bought this car my self from Japan, and picked it up on the dock in Drammen, Norway. I live nearby Kristiansand, in Norway.
Here is some technical specs on the car:
Body type: Hatchback
Drive: FULL 4WD
Transmission: Hyper CVT (non-stage transmission)
Displacement: 1348ccm
Frame: GH-ANK11
Price of new car, thousands yen (Tokyo area): 1297 (~$10800)
Exterior dimensions (LxWxH), mm: 3720 x 1585 x 1430
Interior dimensions (LxWxH), mm: 1705 x 1290 x 1180
Wheel base, mm: 2360
Treads (F/R), mm: 1365 / 1325
Ground clearance, mm: 135
Curb vehicle weight, kg: 960
Seating capacity, persons: 5
Doors number: 3
Min.turning radius, m: 4.8
Fuel tank capacity, l: 42
Engine Displacement, cc: 1348
Engine model: CGA3DE
Max.power (Net), kw(PS)/rpm: 85 ps (62.52 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm: 12.2 kg*m (119.64 N*m) / 4000 rpm
Power density: 11.29
Engine type: Water cooling serial 4 cylinder DOHC
Fuel system: NISSAN EGI (ECCS) (electronic gasoline injection)
Turbocharger: No
Fuel type : Unleaded regular gasoline
LEV system (Low emission vehicle): Yes
Compression ratio: 9.5
Bore, mm: 72
Stroke, mm: 82.8
Fuel consumption at 10-15 modes, l/100km: 6.3
CHASSIS / TRANSMISSION
Power steering: Yes
Tires size, front: 165/70R13 79S
Tires size rear: 165/70R13 79s
Braking system, front: Ventilated disk
Braking system, rear : Drum (leading/trailing)
Suspension system, front: Independent suspension strut type
Suspension system, rear: Independent suspension parallel link strut type
EXTERIOR EQUIPMENT
Rear wiper: Present
ABS (Antilock brake system): Present
Electrical Power Mirror: Present
INTERIOR EQUIPMENT
Air conditioner: Manual
Centralized door lock: Present
Power window: Present
Rear ELR3 point seat belt: Present
Front seat pretensioner seat belt: Present
Fourth limited front seat belt: Present
Side impact bar: Present
Airbag (Driver): Present
Airbag (Passenger): Present
Audio deck: AM/FM radio equipped cassette player
CD-player: Single equipment
Here are some pictures from the "for sale page", and the rest of the pictures
is pictures the seller took of the car before I wired the money to him:
And here's a picture from when I picked up the car at the dock i Drammen, Norway.
And here's a picture on my son finding some ANK11 parts:
The plan for the car is to take out, and sell, almost everthing that came with the car,
and then convert it to LHD, and mount an SR20DET for GTiR.
And also planning to use the front and rear wheel setup from the GTiR,
if I can make it fit the car somehow. But this is going to be a LONG time project.
Drive: FULL 4WD
Frame: GH-ANK11
Doors number: 3
Turbocharger: No
Bore, mm: 72
Stroke, mm: 82.8
Power steering: Yes
EXTERIOR EQUIPMENT
Rear wiper: Present
INTERIOR EQUIPMENT
