PollyMobiles Rebuild
Didn't have much energy today but I managed to crimp the new relay wires together
Reassembled the loom & dash
Couldn't be bothered to correct the wideband wiring (connect 12v supply to the original O2 pink wire, add toggle switch to power-up wideband separately after cranking), check the ECU loom connectors are clean, and many other minor tasks cos it ain't essential yet and it still works ok.
Pump sounds abit stronger during cold priming with the higher voltage. She still drives like normal tonight, the odd rattle in the dash at specific rpm still there 🫣
2025-02-15 Replace Walbro GSS250 255lph Fuel Pump
With approx 75% fuel level I removed the fuel pump assembly out of the tank.
Not a fun procedure, even with gloves 🫣 🙈
Opened the container & oh my god! 😨
This clean face-lift fuel tank was swapped over 1 yr ago but now after filling it with mostly tesco / occasionally morrison fuel, there's soo much crap dirt in the tank/strainer 🫣
Poor pump strainer is covered in filth
Look at this tank! 😬
I guarantee this tank was clean when it was swapped.
Non of this rust crap came from my car (old/new filler pipe wasn't rusty, pump itself ain't rusty).
It must certainly come from the old, badly maintained, cheapo supermarket fuel pumps 🙄
Old vs new Walbro GSS250 pumps
I flushed out as much of the debris off the strainer with can of carb cleaner
Fitted onto new pump
Pump, strainer & swirl pot all clean for now
Here's a comparison of how the pump sounds before/after.
First two clips were with fuel hose unplugged and fed freely into a fuel can with 0psi, while the last clip was with the hose connected onto fuel rail supplying 3 bar of pressure.
Old pump had a higher/faster/louder motor whine whereas the new pump (with fresh tighter tolerances?) has a lower pitch, especially once it's plumbed into the 3 bar fuel rail.
Loads of good work however may I suggest it would be advisable to replace all DIY temporary crimp joints with professional married electrical inline & tee joints soldered & sleeved?
Manifold fuel line/regulator pressures?
Married Electrical Inline & Tee Joints Soldered at DuckDuckGo
Keep up the good work! :)
Gradually working through my to-do list to replace all my nasty old weak solder with crimps 🫣
Next on my wiring list is to sort the wideband wiring.
2025-02-17 Walbro GSS250 Fuel Pump Detailed Look
For a closer look at how the Walbro 255LPH internal gear type pump works and it's condition after 13yrs, I stripped it all apart
& 3D modelled it too
The port in the front plastic cover simply feeds fuel into the pump via this narrow slot.
The round hole at the bottom isn't used for output (maybe on a different model?) but instead it's just blocked off & keeps the front cover aligned
The pump unit separated from the motor casing, driven by these 4 prongs
This thin rigid backplate & brown slippery layer simply keeps the back of the gear pump sealed with minimal wear
The front brown gasket, which does most of the work sealing & controlling flow, seems quite worn.
Potentially the scoring marks maybe due to trapped debris from dirty supermarket fuel getting past the pump strainer 🫣
The gear pump face is also little worn. This will reduce sealing efficiency, less pumping performance, which may explain the higher motor pitch due to loose tolerance, less friction, less hydraulic pressure :unsure:
In the model you'll see as the motor spins the pump clockwise, fluid enters the top slot as the gear teeth opens up.
At the bottom part of the cog, the closing teeth squeezes the fluid out (this additional loose brown 'tab' on the gasket might be used to smooth out the flow?)
Fluid then enters the casing via a narrow slot at the bottom. Seems like a kinda restrictive/rough path? 👀
From that small slot, fuel flows through the motor casing, cooling the motor
The copper longitudinal commutator track, similar to the face-lift fuel pump, looks a little worn by 1mm.
Stator has a clear wrapping maybe for insulation & smoother fluid flow?
After cooling the motor, fuel goes to the rear section through these two holes & gaps in the graphite brush holder
In the rear section, most of the fuel flows through the regular output, which has a 1-way check valve to maintain fuel pressure after shutdown.
For non-return fuel systems, there's also an over-pressure relief valve which bleeds excess pressure back into the tank
The graphite brushes has plenty of life left
I believe these conductive end-caps are press-fitted into the rear section at the last-stage of manufacture so it's easy & fast to assemble the graphite brush springs and test the motor circuit simultaneously :unsure:
Overall an interesting design to check out 😎
Here's a look at the pre-face & face-lift pump for comparison
https://micra.org.uk/threads/pollymobiles-rebuild.35251/page-203#post-884005
Recently noticed hearing a slight rubbing noise once-per-wheel turn only at low speed, shortly after applying brakes and after driving for few mins.
I suspect it might be the caliper rubbing on the edge of the discs (considering they were rebuilt recently) :unsure:
Looking under the passenger caliper, not much signs of rubbing, just some brake pad dust
But the drivers caliper definately has some rubbing from the disc edge
I tried to shift the whole brake carrier further outward slightly but it still rubs after warming up the brakes from few mins driving 🙄
May have to remove the carrier cage and mill the hub upright bolt hole slightly oval to install the whole thing further outwards by 1mm till the top of pads sit flush with the disc edge and caliper has a larger gap from the disc :unsure:
The caliper carrier has upto 2mm gap from the disc edge
Whereas the caliper sits abit closer upto 1mm gap from the disc 🫣
notice the top of the pads have always sat 2mm too low from the edge of the disc
I drilled the bolt hole slightly further outwards to shift the carrier approx 0.5mm from the disc
Can see the top of the pads now sit past the old line on the disc
Went to heat the brakes up in country roads and Nope it still rubs 😤
It sounds more like a rubber seal noise than a metal to metal sound,
Gets louder when cornering right,
& mostly under slight brake pressure but quieter under hard braking 🤔
The last time I experienced a similar thing was a loose wheel bearing due to the LSD.
I lifted the front on axle stands, run it on 3rd gear, apply slight braking and listening to the brakes for any rubbing, nope they're both quiet so they're definately not rubbing.
Both wheels don't show much side-side or vertical play but let's check the passenger shaft nut (which historically tends to loosen with the vibration off the LSD),
& sure enough the driveshaft nut was only loose by 5-10deg 🤏
Tightened the nut hard as I can and went for another drive and that's finally fixed the rubbing noise 🙈😅
Quote; “carrier cage and mill the hub upright bolt hole slightly oval”
Well investigated however needs comparison of discs outside diameter dimensions equality & compared to OEM discs?
Milling/drilling out mounting holes on critical brake components would not be advisable & may introduce parts movement together with stress fractures in future?
Good luck
Good luck
Cheers
All of the GTIR discs I've ever brought have the same dimensions but the main problem is that the carrier cage and/or K11 hub bolt holes on mine makes the whole assembly sit 1-2mm too close to the disc until it rubs at high temp 🫣
But I remember other owners with same brakes didn't have this issue? 🤔
Yrs ago I had new discs machined smaller before fitting, but was uneconomical.
Then I later grinded the bottom of calipers 1mm to clear the disc, but couldn't grind too much out.
This last option here was to just slot 0.5mm of the hole to nudge the assembly out just enough to clear the disc, but given the remaining 10-15mm of thick steel around the hole I doubt it'll affect overall strength enough to worry about for daily driving 🤫 unless i start fitting extremely oversized racing brakes and increase the stress loads on those bolt holes from more trackdays 🙈
T
Cheers
This last option here was to just slot 0.5mm of the hole to nudge the assembly out just enough to clear the disc, but given the remaining 10-15mm of thick steel around the hole I doubt it'll affect overall strength enough to worry about for daily driving 🤫 unless i start fitting extremely oversized racing brakes and increase the stress loads on those bolt holes from more trackdays 🙈Many
Many thanks for your interesting experience based response.
May I suggest shape overrides minimal material removed in order to equally distribute stress lines in circular lacuna compared to oval lacuna stress concentration of the resulting critical brake mounting stress ellipsoid.
Stresses At Elliptical Holes
Good luck
It's been 1yr since I last checked the compression and 2yrs since checking valve clearances 👀
Insides look good from regular 6mth servicing with 10w40 castrol gtx
Compression on all 4cyls are really good & equal :cool:
Ever since I rebuilt this engine with perfect piston ring gaps in 2019 and then tweaked the valve shims in 2022, all of the intake & exhaust now have perfect equal clearances 😃
Nice
2025-03-08 Check Peugeot 307 Fuel Pump
After seeing the terrible rusty debris in kassandras tank (suspecting it's either from the old rusty steel filler pipe or dirty tesco fuel?) I figure it's best to check out the 20yr old peugeots fuel tank :unsure:
The peugeot uses a return-less fuel system & plastic filler pipe (so minimal chance of rust forming) but oddly it has no in-line fuel filter? purely relying on the rough little fuel pump pickup strainer 🤨
Unscrewing the huge 20yr old plastic collar without breaking it was a little tricky but some gentle leverage got it loose
Here's the whole fuel setup, the spring loaded top cover keeps the lower section pressed down close to the bottom of the tank
Very interesting that it features 2 separate swirl/reservoir pots, good for reducing starvation 😎
Fuel first gets sucked into the 1st chamber via this orange 1-way valve close to the bottom of the tank
This lower chamber keeps the pump pickup submerged with afew ml of fuel at all times, even while the rest of the tank is sloshing around
The tiny pump strainer sits at the bottom of this primary chamber and is the only filter throughout the whole system :unsure:
You'll see the pump in the center feeds fuel into a secondary pressurised swirl tank reservoir surrounding it, maintaining a consistant fuel supply.
1 output at the top feeds fuel to the injectors while the bottom output with the blue o-ring leads to the fuel pressure regulator
1 of the black hose from the center pump feeds into the secondary reservoir while the other hose sends fuel from the reservoir to the fuel rail
Looking inside the tank, reservoir & pump strainer it's surprisingly clean & rust-free, even after 20yrs filling up with cheap morrison fuel, which is a relief 😇
2025-03-18 Rebuild Garage Roof
My garage roof consists of a steel mesh cage covered with a mess of clear corrugated sheets, which tends to break from UV damage, high winds or being walked over, leading to annoying leaks over the car for the past few decades and I figure it's time to improve it :cautious:
I modelled the roof & designed an arrangement of 1220x610x4mm polycarbonate twinwall sheets (durable enough to stand over, UV resistant, & most cost effective panel size)
Stripped all the old brittle sheets off the roof shell
Good time to give the rusty frame a lick of paint :cool:
Laid a waterproof sheet over the far wall to form a sort of lower rain gutter and bolted the 1st set of panels onto the sloping roof side
finished bolting the rest of the top panels & sealed all the joins with Gorilla crystal clear tape & regular flash tape
After 4 labour intensive & exhausting days luckily with good weather, I just managed to finish the roofing right before the rain was forcasted that evening.
The next morning with heavy downpour it's a relief to see that my idea worked and I finally have a waterproof dry garage to park kassandra in :cool:(y)
2025-04-19 FLIR One Gen3 Thermal Camera
Brought myself a FLIR usb-c thermal camera for many reasons including:
- check home insulation & heating system
- finding home appliances/electronics that wastes too much power/heat
- checking the cars cooling system, exhaust, brakes etc
After buying it I was disappointed to find that the FLIR app wasn't compatible with my Huawei phone 😫
Thankfully I had a spare samsung tablet with a usb-C port which was FLIR compatible 😇
Initlally thought I brought a faulty used FLIR off ebay cos the camera wasn't connecting with the app but soon got it working after several restarts, reboot, replugging, recharging etc I think it might be a software bug or FLIR battery issue 🤔
It's a really annoying bug but once successfully connected, it'll keep running till the battery runs out.
First thing I did was check/fix the home heating, insulation holes and disable any electrical wasters like TV, Stereo, network adapters, routers, power adapters, fish tank pump, game consoles etc
Then I tested it out on Kassandra during a cold start, which is fascinating & cool seeing how stuff warms up 😎😃
The camera had trouble reconnecting again after I stopped recording 🙄
Figured the camera will connect to the app more likely by restarting the tablet, restart the app & reinsert the camera.
The next day I did a more detailed FLIR look at the car.
@00:05 Exhaust manifold heats up
@01:02 Warming up catalytic convertor
@02:05 Check brake temp after a short drive & coming to a stop
@03:05 Check engine bay temperature
@05:30 Exhaust silencer temperature
@05:50 Test cabin heater
@06:15 Hot engine bay after parking car in garage
@06:45 Engaging radiator fan
@08:25 Testing universal ebay catalytic convertor
So it turns out that the cheap 2.25"universal stainless sports cat I brought off ebay used on this new manifold might actually be a fake :cautious:
After warming up the engine and holding high rpm, the core of the cat doesn't get hot at all and there's no temperature difference between both ends, meaning there's no reaction or any catalyst material within that fake honeycomb core, which might explain the really high emission readings during her MOT in january, even after revving her nuts off for 3min, and yet she passed easily after reinstalling the standard cat.
Also the rear left brake might be sticking slightly, making the disc appear a little warmer.
2025-04-19 Replacing Catalytic Convertor Core
After discovering my current universal cat is fake & doesn't work, I wonder if I could replace it with some used oem cats I had in the garage cut to length 🤔
This cat from an Octavia had a spiral steel mesh core, which made it really difficult & slow to cut through
Unfortunately the rough bandsaw teeth would end up bending all the fine steel mesh, clogging the whole thing 🫣
The other longer bigger cat was from a peugeot 307, which has a regular ceramic honeycomb core.
I cut both ends off
Due to the softer ceramic honeycomb it was easier for the bandsaw blade to cut through and the hard/brittle ceramic material would cut/crumble cleanly
The result is a clean, flat cut with no clogged pores, so it's possible 😎
The universal cat is 102mm diameter whereas the peugeots cat is 105mm diameter, near enough.
Plan is to cut this core off the current exhaust
Cut the peugeots core to length (want to use as much honeycomb length/volume as possible to give it more chance to help improve emissions) and weld it on like this
2025-04-20 Compare Fake Cat vs Genuine Cat Using FLIR
Here's a comparison of the fake catalyst on my Micra vs a working cat on a Peugeot.
During Cold Start: The manifold gets hot immediately, catalyst core stays stone cold, and downpipe begins to warm.
After Driving 10min: manifold is very hot, catalyst core & downpipe are at their warmest.
After Idling in Garage: manifold stays hot but catalyst & downpipe has cooled down.
Holding 3k rpm for 3min: manifold gets hotter but catalyst core & downpipe stays same temperature.
The Peugeot 307 with a working cat is very different.
During Cold Start: manifold & downpipe gets hot immediately, upper half of the catalyst is cold, lower half of catalyst warms up quickly as the gas flow reacts & gets hotter.
Idling 1min: upper half of the catalyst begins to heat up from reacting with gases.
After Driving 10min: the whole exhaust system is very very hot beyond the 150c limit of the thermal camera 🔥
Comparing the brakes & exhaust silencer temp of the Micra with the Peugeot after 10min of cruising and both appear with similar appearances.
2025-04-21 Replacing Fake Cat with Genuine Cat
Began removing the fake universal cat
Looking at how close the cat is to the block, I decided not to fit a longer catalyst core
Can see some signs it only got hot at the top near the manifold but the fake honeycomb core and the lower outlet never got hot enough :cautious:
Chopped off the funnel ends.
The fake stainless cat is 101mm diameter while the Peugeots cat is 105mm diameter.
Top of the honeycomb only a little soot but doesn't look like it got hot
Bottom of the honeycomb looks the same light pink as when new, indicating no reaction or high heat.
Normally the hotter exit end of a used cat would appear pale & white from the intense heat of reaction.
I chopped the spare Peugeots catalyst core to match the same length
Clean cut
Dremelled loose some of the white insulation fibres between the honeycomb and steel casing to allow the smaller funnel ends to slot within the groove
Tacked & welded together
As a reminder, here's the thermal image of the fake cat which never got hot at all
And now with a working genuine core taken from a spare Peugeot 307, you can clearly see the cat & downpipe getting hotter from reacting with the exhaust gases and high rpm 🔥
Here's footage comparing the two
Hopefully for her MOT next yr this will help with emissions 🤞
2025-04-28 Testing Fake Cat vs Genuine Cat with Blowtorch
I discovered a difference between the fake cat and the genuine cat using a blowtorch.
When I aim the hottest part of the flame at the honeycomb they both get white hot as expected.
But once I move the torch closer so that the cooler & butane rich part of the flame reaches the honeycomb, the fake cat has no catalyst coating to react with the cold rich mixture or any flame to maintain heat therefore it cools down instantly.
Meanwhile the catalyst in the genuine cat continues to react with the butane gas keeping the honeycomb white hot & notice it also cools down much slower after I remove the flame.
2025-05-06 Weld Squeaking Chassis
Today I managed to find the cause of that annoying hidden squeak which appears to be a cracked spotweld in the door frame
Wedging it with a screwdriver clearly shows the crack.
Little odd to see that the cracked passenger side are two thin sheets whereas the drivers side has this extra thicker reinforcement plate added on the back 🤔
Adding afew plug welds along the cracked seam
Grinded & painted
Cruising along the motorway she is now FINALLY nice & quiet with no more annoying rattles/buzzing 😎😇🥳👌
2025-05-07 Removed Rear Door Handles & Window Mech
Since the rear door handles & window mech are never ever used, I decided to remove them all to eliminate any rattles and hold the glass solid with these brackets
The brackets secure the glass onto the door panel
Drilled 2 holes to fasten the brackets
No more things to rattle in the door, save afew grams too lol
2025-05-17 Swap Back to Standard Engine Mounts
Whilst cleaning the garage I found some spare oem engine mounts and decided to swap them back to reduce the shaking
These firmer mounts I got from matt humphris yrs ago are still soo stiff/rigid compared to the mushy oem mounts 😬
No wonder it's been shaking kassandra apart for the past decade 😅
cba to replace the front & rear mounts but after simply changing to softer left & right engine mounts, the vibration through the steering & door mirrors overall seem to be halved and alot smoother & quieter when cruising (y)
I rather suspect that the original K11 Nissan Micra design engineers & Sunderland factory got the K11 right from the get go in 1992?
My 1998 K11 1300cc is all original unmolested & just keeps going with only my simple DIY servicing in my shed every 2 or 3 years & no worries. My K11 still has the original Nissan exhaust system!
The only design flaw was putting the MAF sensor & air temp sensor + PCB card rigidly fixed inside the TB where it is too close too the the intake manifold & subject to engine heat & operating & air harmonic vibrations?
That’s good enough for me. :)
Yeah good enough compromise for a smooth comfy drive.
Fitting my PTFE manifold gasket & removing the TB coolant lines made a huge difference in keeping the intake stone cold 😎
Yup I can't imagine all that heat & vibration is good the delicate MAF electronics 🫣
So tonight I swapped it all back to standard engine mounts and removed that solid printed rear mount insert to allow movement
Standard front mount has upto 20mm of loose movement which doesn't help 👀
The previous solid mounts gave a sharp, instant, visceral, positively engaging & enjoyable feeling of being connected to the cars machinery.
But now with standard mounts, jesus! she feels completely different 😦
Firing up the car no longer shakes the body, it just poofs into life quietly.
When idling, the steering & body no longer shakes and is really quiet, I had to check if the engine was running 🤔
The biggest change is the mushy clutch engagement and lack of vibration in the steering, so setting off from standstill and acceleration feels soo disconnected, floating, hard to judge.
Cruising at speed is very nice & smooth 😎
Without the shaking steering/dash/body, the boomy exhaust at the back is now more noticeable 😅
Think I'll reinstall the solid front mount to see if that improves the feeling slightly :unsure:
The standard front mount has soo much slack upto 11mm that I could noticeably rock the engine back/forth & see the softer left & right oem mounts move, overall this leads to a spongey disconnected feeling with the clutch & throttle response.
I swapped back to a solid front mount, left & right mounts are the softer oem, rear mount is the firmer version but without the solid 3d printed inserts.
This made a noticeable improvement. The sharp connected feeling of the clutch & throttle is back to normal while most of the harsh noisy shaking vibrations at low rpm & cruising are gone, a good compromise 😎
The completely solid front upper & lower mount (on right) with firm rear mount and OEM left & right mounts was still transferring abit too much vibration to the dash & steering.
The standard front mount (left) has a medium-soft upper bush but the large lower bushing fits soo loosely upto 11mm vertical play and 6mm lateral play 👀
So the next layout to try is OEM front upper, left & right mounts, firm rear mount, and a solid front lower bushing.
Went for a drive in the sun and yup it drives very lovely now :cool:
The front/rear/left/right rubber bushings absorb most of the engine vibrations throughout the rpm range while the solid front lower bushing prevents large rocking movement improving the feel & response of the engine/clutch (y)
2025-05-27 Reroute Front Breather Pipe
The front crankcase hose is at a tight angle making the route for future catch cans a little tricky
I removed the 90deg elbow from a spare cover
Welded together to form an S-bend
Now the hose has a smoother curve and will be easier to plumb the catch cans to the right side of the bay
2025-06-05 Remove Rear Axle
The rear axle was starting to get abit crusty and needs repainting 🙈
First I removed the brakes, the inner side of the discs towards the caliper piston appear slightly pitted (maybe from sitting in garage for weeks?), the left disc is less pitted & more scored probably cos the left caliper sticks more than the right :unsure:
Wheel bearings still nice & tight
Left hub nut was really tight to get off 💪
Stainless fuel filler pipe still clean, slight surface rust at some of the welds
While removing the panhard, I found the lower half of the bracket has now cracked off the axle 😬 probably from rust and fatigue of the solid polybushes bending it as the axle swings & tilt naturally during suspension travel & braking 🙈
I'll weld a stronger box mount onto the axle.
Ideally I should probably convert to a rose-jointed panhard rod allowing the axle to swing freely without putting extra stress on the mount & panhard 🤔
Axle removed, right spring was stuck on the axle so I'll try remove it tomorrow
2025-06-19 Wirebrush Rear Axle
Managed to pry the RH spring off & snapped the rest of the panhard mount off 🙈
Wirebrushed as much rust off the axle, overall it still appears solid :cool:
Grinded the old snapped bracket flat
Removed most of the rust
Cleaned the whiteline trailing arms too
Removed the stuck solid bushing off the snapped panhard mount, there was literally zero clearance in that bush, woops 🫣
The mount itself uses quite thin brackets thich eventually rots & snaps off
Forgot which way this OMP left/right hand adjuster screw on the panhard rod loosens and it was seized 🤔
So I chopped the end off 🫢
Cleaned the threads, not that it'll be used again
The whiteline panhard uses a 27mm x 3mm thick tube
Brought a new 1m length of same tube to make a new panhard
Sourcing new polybushes for this whiteline panhard was difficult since it's no longer available and universal replacement bushes online don't show any dimensions to check if it fits 🤔
Machining new bushes on a mini lathe with soft polyurethane rod I heard is also very difficult.
The only other option is to convert to a custom rose-jointed panhard rod, which also turns out slightly cheaper than buying polybushes 🤨
Brought a pair of M16 left/right threaded rose joints, nuts and dust boots
2025-06-21 Weld New Panhard Rod Mount
I was waiting on this ebay M16 bolt for the panhard mount but realised it's coming from china & won't arrive till next month :rolleyes:
Halfords sold M16 towing bolts but imo they were too short (rose-joint would be resting on the weaker threads rather than the solid shank).
Returning home I stopped by my local fastener shop who actually had the correct M16 x 100mm bolt and much cheaper too 😅
Begin making these large washers for the mount from 1.5mm steel
& machined the bulky hex head off the bolt to help fitment against the axle.
New mount is assembled like this
Welded the supporting washers onto the bolt
Attached the assembly onto the 57mm round tube body
Welded the backside
Trimmed the mount to sit on the axle at exactly the correct position & angles after alot of fiddly grinding
Welded new panhard mount onto the axle, hopefully it'll be much stronger than before :cool:
2025-06-21 Make Rose Jointed Panhard Rod
Welded the nuts onto the new steel pipe
Attached the rose joints
Machined this tapered spacer to help spread the load
Rose joint sit on the shaft like this.
Overall length is 50mm same as the original bushing, therefore if rose-joints didn't work out I could revert back to poly bushes
New panhard rod & axle mount finished. The rod can now swing freely with zero friction and no play :cool: 👌
2025-06-24 Install New Rear Axle
Had to trim the inside lip off these spring cusions so that the spring doesn't jam on the spring seat
Now the spring has room to move without binding
Installed the axle.
When moving the axle up/down it's full travel without springs, I can clearly see it tilt forward by approx upto 10deg probably due to the upper trailing arm sitting at a steep angle and the lower arm sitting flat when lowered 50mm.
No wonder the old stiff panhard with solid bushings snapped the mount 🙈
This new rose-joint panhard with high range of movement should stop it happening again.
Attached brakes & aligned the wheels
Printed this cover to protect the exposed adjustable trailing arms from rust
Going for a test drive after waiting 3wks, I forgot how nimble she is 😁
Handling feels sharp, quiet with no knocks/rattles 😎
2025-06-26 Inspect Fuel Tank for Debris
So I swapped to a clean facelift tank since March 2024
Changed to a stainless filler pipe in Dec 2024
Replaced the Walbro pump in Feb 2025, which had all this dirt around the pickup
Lets quickly check the state of the pump in June 🤔
Pump removed
Hmm not bad, just a small amount of dirt :)
Little specks in the tank but ohh..
ohhh looks like poor little Geoffrey the spider got inside the tank and half dissolved 🫣
Personal Update 2025-08-17
It's been a difficult 2025 for me with no signs of hope 😞
Left a terribly uncomfortable & brief job in January as a caretaker, realised I got used & manipulated again by women & close friends 🥺
Which inevitably triggered me to delete everyone & everything out of my life since I can no longer trust anyone or even myself.
No social media, no friends or social life, no income, completely self-isolated, lost all confidence, lost interests in most hobbies, no exercise, & suffering through my 4th depression & anxiety 😭
Obviously I needed to find some sort of job or income while in a bad state to pay bills etc, so signed onto Universal Credit in Feb in hope of refining my CV, seek advice on what jobs suit me, & getting some small financial support.
But still after 7mths of trying to apply for jobs in design/engineering/CAD/delivery/factory/etc with zero results or replies, I feel completely useless, lost, broken, stupid, scared, sad, wanna give up 🫣
Years of studying product design in college & universities wasted, unsure where I belong anymore 😒
Going through this depression alone with the same patterns/mistakes, I've often wondered what dafuq is wrong with me!? Why can't I find any job while I've seen everyone else doing it easily like buying groceries?
I've long been suspecting I might be autistic with ADHD? so I seeked ADHD diagnosis since April and after a brief video call in July I was told I have inattentive ADHD and will be given some meds soon, which I guess is a slight relief towards explaining my life struggles and hoping it'll help me focus on job searching with less anxiety or distractions🤞
I'm aware no one will probably see this message since this forum has long been deserted, but I have nowhere else to talk to/express myself and just wanted to document my thoughts here alongside my project blog 🫥
2025-07-04 Shorten Bonnet Hook
The bonnet seems to sit slightly too far up and the latch is already at it's lowest position, so the only other option is to shorten the bonnet hoop itself
Chopped
Welded, and now the bonnet can sit lower to the headlights/grill
2025-08-10 Convert Heater Blower Resistor Card into PWM controller
Recently noticed the battery is again not fully charging up towards 12.6v cos it's only receiving upto 13.9v while the running alternator produces 14.2v 🤔
Some of the voltage drop came from the main battery 65a fuse in the engine bay (-0.05v)
Tested the resistances of all the spares with no difference between them at 0.01ohm, so nothing I can do about that
The worst drop comes from the heater fan resistor card constantly draining at least 0.1v even at low speed, which won't help with battery life or mpg.
I had a spare 12v PWM controller and was curious to see if it'll work more efficiently than the old wasteful OEM resistor pack 🤔
Roughly wired up the PWM controller inbetween the fan motor & circuit, turned the micra fan dial to a full #4 (bypassing the resistor card circuit & sending full 12-14v to the PWM controller)
Results are:
*Fan turned off, ECU not signalled to "idle up" : 14.05v
*Fan ON with PWM at 0% : 14.04v (really low PWM duty cycle doesn't consume much voltage)
*Fan Speed #1 with PWM at 25% : 14.02v (some of the energy is still being wasted by the resistor card)
*Fan Speed #4 with PWM at 25% : 14.00v (PWM runs fan at same rpm as OEM dropping by only 0.05v)
*Fan Speed #1 with PWM 100% : 13.95v (running the factory low fan speed through the resistor card drops it by 0.10v, wasted as heat)
*MAX Fan Speed : drops to 13.62v
So the PWM does work better than factory. Next task is to neaten the installation.
The other day I was only briefly using this old battery grinder for just 10sec and whilst looking away finishing a task, I suddenly noticed the workshop is abit smokey only to see the lithium pack firing up! 😱
ohshtohshiiohhshyt 💩
1st time I ever had a lithium thermal runaway, I calmly picked up the smoking grinder and quickly took it outside in the back alley to soak with the hose while just one of the cells gave a flaming pffffffsh 🔥
Good thing I was able to spot the smokey grinder in the garage otherwise it could've been bad 😬🫣
2025-08-16 Fix Citroen C3 Master Cylinder Long Travel Issue
For the longest time ever since I fitted a larger Citreon C3 M/C in 2015 to match the bigger volume of the GTIR front calipers, it's always had this annoyingly long initial dead-zone in the pedal before any braking pressure is felt so I had to extend the pedal resting point high up to compensate 👀
There must be some issue between the citreon MC & micra servo, so I began to remove the assembly
Split the MC, which I had tigersealed tightly onto the servo 🫣
After a quick measure, I realised theres actually a big gap between the pushrod in the servo and the MC piston it engages with 🤨
Here's the factory servo pushrod, which has a threaded & crimped round tip
It was crimped but can be unscrewed/adjusted
Dismantled the rest of the Citreon MC to measure & assess
Here's the primary piston. Notice the square rod in the middle, which is part of a relief valve (allows fluid to flow freely to/from the reservoir only when the piston is fully retracted back)
Here's the secondary piston. The little pin at the front is also the relief valve, activated by this vertical rod when piston is fully retracted
I modelled all the components
So in the old layout you can clearly see the factory servo pushrod was upto 10mm far too short for the Citreon MC, no wonder there was soo much floppy pedal travel 🫣
The solution is to simply lengthen that pushrod by 10mm, whether by simply unscrewing it (barely enough thread left and too weak), or preferably by machining a longer/stronger M6 screw to fit
This is when the MC is fully compressed, checking the servo diaphram has enough travel without hitting the end of the MC
Tomorrows task is to machine a longer pushrod for the servo and reassemble everything 😎
Managed to find an M6 screw of the correct length
Pushrod sits at the right spot where the CAD model says
Machined a deeper groove for an O-ring to seal onto the brake servo
Filled & bled the air out of the MC like this
MC & servo ready to fit
While bleeding & checking brakes, may as well check how straight the discs are too.
Brake disc run-out limit is 0.07mm
all the discs are 0.05mm except for the rear right corner which has a massive 0.30mm run-out :unsure:
Tried wirebrushing both surfaces clean and remounting the disc onto the hub at 1/4 turns with no improvement.
Apart from remachining the disc straight or replacing it, the alternative option is to simply apply a layer of tape inbetween the hub face to straighten the disc alignment 😁
And now it's at 0.05mm within the factory limit :cool:
Reassembled the car for a test drive.
After starting the car & leaving the garage, initially I thought the pedal travel seemed extremely short, instant braking response with absolutely no dead-zone, really sensitive braking 👀
Moving the car really slowly, I could feel the brakes are actually dragging slightly :rolleyes:
Lets drive round the corner, maybe it'll loosen up?
Hmm it actually got worse as all 4 brakes quickly heated up, expanding & binding up even harder to the point where I had to floor it WOT in 1st/2nd gear just to keep moving till I found a parking spot 😬🫣
Erm yeh so I guess the servo pushrod was a bit too long, jamming the MC on and unable to release.
No wonder the pedal felt too firm & sensitive.
With the hot brakes jammed on hard, I had to briefly loosen the MC pipe to relieve the pressure allowing the calipers to release so that I'm able to nurse her back home. Instead of pressing the pedal and jamming the brakes again, I ended up using the handbrake to slow down for corners 😅
Back at home wondering what I got wrong, I guess the pushrod was moving the pistons further than expected when operating with engine vacuum.
To check the rods resting position with or without vacuum, I removed the MC and simply covered the hole with clear tape, run the engine and I could see that the rod moves forward by 1.3mm under vacuum
So with the vacuum nudging the shaft forward slightly and the M6 screw slightly too long, this pushes the piston away from their full retracted position, where the relief valves are actually kept closed and unable to bleed any excess pressure from the calipers back to the reservoir, basically keeping the brakes locked on
I've now shortened the screw by 5mm, which should hopefully allow the pistons to retract fully, opening the relief valve and allowing the calipers to relax
Just need to rebleed the system tomorrow for another test
With the pushrod shortened by 5mm, I bled the brakes again,
started the car with wheels lifted,
pump the brake pedal few times,
recheck none of the wheels are binding,
went for a drive and now it's working properly 👍
*Pedal has approx 20mm if initial travel before it reaches the bite point & firms up (much shorter than the previous 35mm of travel) meaning the pedal can rest at a lower point, closer to the throttle pedal.
*Braking sensitivity is back to normal compared to when it was stuck on
*Brakes fully relax without any binding when releasing the pedal
I have always associated rechargeable battery equipment fires with cheap rechargeable equipment fire starting thermal runaway when charging unattended & with mismatched cheap chargers?
To avoid such unnecessary risks I always run out an extension lead & use power tools which are more powerful too get the job done quicker when working near where mains power is available.
I brought the cheapo small & large batteries & charger as a set on ebay yrs ago.
Could it be the charger or battery controller slightly overcharging & damaging a cell over time or is it a random roll of the dice?
Both batteries are also beginning to hold less total charge.
Just odd how it didn't catch fire on the charger or while under full load and instead fires only after a brief use?
While the regular corded grinder is reliable & powerful, great for very long cuts or wirebrushing, it's just too noisy and violently runs at full whack, not ideal for a quick gentle wirebrush.
Cordless grinder is a lot more convenient, portable, runs quieter and kinder on wirebrushes with the variable speed but due to the battery issues I may just have to store it away from anything flammable 🫣
2025-08-25 PWM Fan Controller Extension Wiring
To make a longer & neater loom for the PWM controller, I grabbed a spare blower fan from Jack to use the extra connector terminals
The newer fan on the right sits slightly further up, probably due to the rubber mount inside
Same components
The older fan on the left is certainly more worn out with the brushes sitting further down compared to the newer fan on the right with brushes sitting higher up 👀
Made this 1m extension cable from the old blower connectors
Taped the controller here temporarily for now.
One day I'll eventually integrate it into the factory fan knob
Quote: “cheapo small & large batteries & charger as a set on ebay yrs ago
I automatically associate cheap tools, equipment & aftermarket parts from such sources as being of unregulated unknown provenance & or quality control rejects that find their way onto the UK secondary market?
When we go on holiday three times a year, I store my laptop battery in a fire proof metal box outside the house.
When using power tools I always use industrial hearing, eyes & hands protection to get the job done safely asap.
Welcome back to the MSC after your break, & I have learnt much from the details & photos in your blog over the last 15 years.
Good luck.
Good luck.
That's true 🫣
Thanks m8 (y)
2025-08-29 Inspect Worn Denso K16TT Spark Plugs
These Denso K16TT I fitted in 2021 are getting old now.
You can see in the following pics how the sharp square tip has worn away after approx 10-20k :unsure:
Here's a timelapse of the tip wearing away
Time to replace them 👀
