Basically, looking at getting a Peter Lioyd but was wondering if it's a manifold back system or not? And if not what else would be needed to make it a manifold back...
Ta
it still has like the bulb bit in the pipe, but its empty, Sounds really nice if your putting it on a facelift though you will need to have the egt sensor bolt welded onto it im yet to have that done
Yeah I just spotted that too, You shouldn't have an issue then literally a straight fit and as far as I can tell the sensor is basically there to make sure the lambada sensor is doing its job, so I need to have it put it when I get a chance ahha
