Panhard Rod
Kirton
Renault Sport
This might sound daft to some people, but what does one of these actually do? and is it worth £90 to have?
Panhard rod allows the rear axel to be realinged after you've lowered the car...otherwise the wheels sit out further on the drivers side (iirc).
But they shouldnt cost you £90 think the whiteline one is only £45.
It is important if lowering more than 35mm, dusk lowered his 40mm and his alignment was way out after, his drivers side rear wheel as almost out of the arch and the passenger side rear was far in, we had to pull on the axle and fit the panhard to get it corrected.
he drives a k12 though, probably more expensive. Wait until you lower your car dude. But does a k12 run a panhard rod setup?
