painted front lip/splitter
was given a front lip any know if its possible to colour code to bumper colour,as noticed it feels like a rubbery type plastic,so wondering if it will stick?
If you sand it back it gives a rough surface for the primer to stick too, obviously not visibly rough but enough for paint
Yea can get plastic primer, but standard stuff will do the job
Gonna want to do plenty of coats and let them harden properly cause that area will be prone to stone chips
Just read your earlier post properly about it being ridged, if you're gonna bend it then yea the paint will crack and flake
Why would it be bending though?
Can get stuff called plastic dip, bit more expensive but its supposedly flexible as its like a rubber coating, also no sanding or primer required
