new NA project started
CMF_SSUK
» CMF Member
I have one of the March ST type boxes and shafts but have yet to drop the plate LSD standard CG13DE box out to attempt to replace it.
Wondering what extent of modification is required to the bellhousing and rear engine mount....
farkin jesus, can't believe you put those pics up kovert. it looks ****house in those pics lol.
LowMicra WROTE:
"What are you running as regards to ignition setup? I see the dizzy is modded? That's why I ask, because if you look at the N2 March Cup car it runs a dizzy and leads?
all that remains of the factory dizzy is the outside casing mate, 2 optical sensors run in conjunction with eachother, one mounted inside the factory distributor housing, and another, which you can't see which includes the factory gearbox backing plate being modified using another optical sensor having the jun flywheel trigger it when required. ignition is controlled via a autronic 500r which is controlled by the smc.. total overkill for this car, but the best you can buy. this system could easily see 60pound+ in a turbo car, let alone an n/a screamer
edit: should also mention that the 500r is then incharge of firing 4 seperate coils which fire the spark plugs
SSUK WROTE:
"I have one of the March ST type boxes and shafts but have yet to drop the plate LSD standard CG13DE box out to attempt to replace it. <BR><BR>Wondering what extent of modification is required to the bellhousing and rear engine mount....
quite a few of the bolt holes had to be slightly modified and machined out. gear selector fork must be removed and replaced with a later model one and/or modified to use the stock k11 linkage, or alternatively could probably use the k10 linkage with the k10 gearbox, rear gearbox mount/engine mount bolts don't line up, redrill engine mount, get longer/shorter bolts as needed.neutral/reverse plugs need rewiring.
kovert.k11 WROTE:
"with the forged engine for the forced micra in the process of being built, tmrs and i have commenced another project - this time a naturally aspirated weapon..<BR>thus far, this is what's already in/on, and what bits have been amassed for the job...<BR>installed/done:<BR>TEIN Sports Spec Driving Master Type HA Coilovers<BR>Aspect extractors<BR>Custom 2" Mandrel bend exhaust with Kustom Bitz Performance Weaponry High Flow Race Cats Catalytic Converter and Roxy Semi Titanium Muffler<BR>Whiteline Front & Rear Swaybars, Panhard Rod, Drop Links, Castor Kit & Camber Bolts<BR>JIC Lower Control Arm Brace<BR>Sard FPR<BR>Greddy Oil Catch Can<BR>Volk GR-N 15X6.5" rims (powdercoated black) with Advan 195/50R Semi Slicks <BR>15mm Billet spacers on the front<BR>Recaro Evo 8 seats on Bride rails<BR>JDM Tail Lights and Depo Blk Headlights/Clear indicators (will be swapped for smoked)<BR>Rear wiper removed<BR>ABS & A/C removed<BR>Front and rear guards rolled and flared<BR>Windows tinted sexily<BR><BR>Here's what's to go in...<BR>Hi-comp Japanese built CG13 (revs to 9000rpm) - CG10 pistons, bore/hone, port polish, head skimmed with JUN titanium valve retainers, Nismo valve springs, Nismo metal head gasket, Aspect camshafts (in. 256, ex. 264), Mulholland Adjustable Cam Gears<BR>RS5F31V K10 SuperTurbo Gearbox with Nismo RS5F31V shafts<BR>Keihin FCR39 Carb Kit<BR>Nismo Clutch<BR>JUN 3.6kg flywheel<BR>Autronic SMC & 500R with ignition sensor setup and coils<BR>Mulholland radiator, thermostat and lightweight water pump pulley<BR>Billion Silicone hoses<BR>Trust S13 Oil Cooler Kit (full JDM yo! - haha)<BR>Humphris Rear Adjustable Trailing Arms<BR>Front Tensioners<BR>B-Crews Engine Brace<BR>Power Steer<BR>Cusco Safety21 6-point cage<BR>Complete Nismo bush set<BR>Gti-r front brakes<BR>Defi din mount unit & sensors<BR>Auto Meter Air/Fuel & Juran Exhaust Temp Gauges<BR>Nardi steering wheel and boss kit (& pedals if i can track some down)<BR>C's short shifter<BR>Odyssey battery (relocated to under passenger seat)<BR>JDM front bar & spoiler (w/LED)+Nismo grille, front/rear lip<BR><BR>will continue to update on the progress as the saga unfolds<BR>here's what she looks like presently... feedback most welcome<BR><BR><BR><BR><BR><BR>
nology high energy cdi coils w/twisted pair tfezel wiring
custom cdi coil leads
+ custom 1.5L alloy under car surge tank
carter lift pump
-6 lines throughout
deleted return line from engine to fuel tank
holley fuel reg
billion racing p/s tank
petterson oil catch can
modified cam cover/breather system
custom 1.5L alloy overflow bottle
completely deleted engine bay fuse boxes/abs etc, custom mounted under dash
ACR racing fuel filter
custom alloy fuel distribution rail
and not that it matters, but we used a "full river" dry cell battery this time around, they are actually slightly smaller + lighter.. and offer a better warranty!
also worth mention is the tein coilovers. anyone interested in buying a set: i've only ever seen one set of this model available..this set.. the normal "cool master" teins are rubbish.
CMF_kovert.k11
» CMF Member
thanks for fielding those inquiries and amending the parts list tmrs... fitting considering ur the one in this partnership that is doing all the work... fukn awesomely i might add! lmao.. and in regards to ur disbelief about my posting pix, the **** looks pretty sweet imo mate
LowMicra WROTE:
"turbo march-rolling shell WROTE:
also worth mention is the tein coilovers. anyone interested in buying a set: i've only ever seen one set of this model available..this set.. the normal "cool master" teins are rubbish. "</div>
what are you talking about with this TMRS??
are they for sale?? How Much??
no Low, they are not for sale - tmrs is referring to the coilovers that are on my car and the fact that he's only ever seen the one set which are the ones i'm running
CMF_SSUK
» CMF Member
"SSUK WROTE:<BR><BR>"I have one of the March ST type boxes and shafts but have yet to drop the plate LSD standard CG13DE box out to attempt to replace it. <BR><BR>Wondering what extent of modification is required to the bellhousing and rear engine mount...."</DIV><BR><BR>quite a few of the bolt holes had to be slightly modified and machined out. gear selector fork must be removed and replaced with a later model one and/or modified to use the stock k11 linkage, or alternatively could probably use the k10 linkage with the k10 gearbox, rear gearbox mount/engine mount bolts don't line up, redrill engine mount, get longer/shorter bolts as needed.neutral/reverse plugs need rewiring.
Yeah, I noted the smaller bolting holes in the March box. I was considering to make up some studs to avoid boring out the bellhousing as it's not as meety as the K11 variant. Are they ok overbored to M10?
I didn't note any differenced on the selector fork but I probably wasn't looking that hard. I have a spare K11 box, so a swap isn't an issue.
Regarding the rear engine mount, I guess I will have to get the box up on the car to see the differences in alignment on the rear engine mount.
Thanks for the tips, greatly appreciated :) Super build by the way, the attention to detail and the quality of aluminium parts you have used are exquisite. Have you considered making any of that in kit form for the K11 as a bolt on retrofit? I'd be very interested if you do, I'd sure like some of that gear over here on my track car! We have basically the same setup except for a set of Jenvey throttlebodies instead of the FCRs.
SSUK WROTE:
"turbo march-rolling shell WROTE:<BR><BR>"
SSUK WROTE:<BR><BR>"I have one of the March ST type boxes and shafts but have yet to drop the plate LSD standard CG13DE box out to attempt to replace it. <BR><BR>Wondering what extent of modification is required to the bellhousing and rear engine mount...."</DIV><BR><BR>quite a few of the bolt holes had to be slightly modified and machined out. gear selector fork must be removed and replaced with a later model one and/or modified to use the stock k11 linkage, or alternatively could probably use the k10 linkage with the k10 gearbox, rear gearbox mount/engine mount bolts don't line up, redrill engine mount, get longer/shorter bolts as needed.neutral/reverse plugs need rewiring."</DIV><BR><BR>Yeah, I noted the smaller bolting holes in the March box. I was considering to make up some studs to avoid boring out the bellhousing as it's not as meety as the K11 variant. Are they ok overbored to M10?<BR><BR>I didn't note any differenced on the selector fork but I probably wasn't looking that hard. I have a spare K11 box, so a swap isn't an issue.<BR><BR>Regarding the rear engine mount, I guess I will have to get the box up on the car to see the differences in alignment on the rear engine mount.<BR><BR>Thanks for the tips, greatly appreciated :) Super build by the way, the attention to detail and the quality of aluminium parts you have used are exquisite. Have you considered making any of that in kit form for the K11 as a bolt on retrofit? I'd be very interested if you do, I'd sure like some of that gear over here on my track car! We have basically the same setup except for a set of Jenvey throttlebodies instead of the FCRs.
the holes seem fine bored out that little extra bit. there's bugger all difference.. but enough for the orignal k11 bolts not to fit. same with the selector.. you wouldn't tell a difference untill you have both in your hand.. i didn't untill it was in the car.. absolute pain in the ass to change over in the car.. so make sure you change them over before you put it in... not really interested in making a kit for the k11.. imo, there's no money in it.. i'd probably sell 2 or 3 kits at best. plenty of dreamers, but not many people have any money.... after all.. we are modifying a cheap car to begin with.. anyone with money generally starts off with a better platform :). that said, there's nothing wrong with spending money on em.. between me and kovert i reckon if we put together the money we've spent on our micra's we'd have a pretty awesome house and land package lol
CMF_SSUK
» CMF Member
Cool, I shall take a look at the boxes when I arrive back in the UK later this month. I live in Norway now, so time on the car is limited.
Regarding kit parts, I was being purely selfish when asking for kit parts and was asking for myself rather than for the masses ;) I'd be more than happy to cover all material costs, plus your time & some kind of markup for gear of that calibre.
SSUK WROTE:
"Cool, I shall take a look at the boxes when I arrive back in the UK later this month. I live in Norway now, so time on the car is limited.<BR><BR>Regarding kit parts, I was being purely selfish when asking for kit parts and was asking for myself rather than for the masses ;) I'd be more than happy to cover all material costs, plus your time & some kind of markup for gear of that calibre.
haha. i kinda gathered as much. still not interested mate. only reason i do stuff for kovert is because he takes a stock car and bombs the crap out of it in one hit... its kind of a package deal, that and i enjoy building a car without the 'yeh, we'll do that next time attitude'.. <very common here lol. i used to do bits and pieces for random customers, it all ended when one or two people whinged about pricing.. yeh.. i probably am on the pricy side.. i don't care what bob down the road thinks his time is worth.. go to him if your worried is my attitude. :).. that said. anything i do isn't state of the art cad drawn craftsmanship. i'm sure you would be able to find some alot closer to you then the other side of the world :).. and cheaper! or give it a crack yourself! .. it is kind of hard with micra's thou.. when i first started modyfing mine all people did was laugh.. gave me the drive to make it kickass thou!
CMF_SSUK
» CMF Member
No worries tmrs, the whole car is aeroquip'd anyway, so I am sure I can conmission someone to do the work. I fear living in another country is going to turn me into a 'chequebook tuner', where I get everyone else to do the work and simply sign off checks for the work.
The only problem is finding someone within a sensible distance, you wouldn't believe how hard it is to find a capable fabricator who can properly weld stainless and make a proper exhaust system etc for a car. It seems people are in trouble financially in the UK but at the same time the motivation for people to work seems really low, very odd!
Will keep my eyes on the build, quite interested in the Japanese built engine and seeing what it puts out and where :)
SSUK WROTE:
"No worries tmrs, the whole car is aeroquip'd anyway, so I am sure I can conmission someone to do the work. I fear living in another country is going to turn me into a 'chequebook tuner', where I get everyone else to do the work and simply sign off checks for the work.<BR><BR>The only problem is finding someone within a sensible distance, you wouldn't believe how hard it is to find a capable fabricator who can properly weld stainless and make a proper exhaust system etc for a car. It seems people are in trouble financially in the UK but at the same time the motivation for people to work seems really low, very odd!<BR><BR>Will keep my eyes on the build, quite interested in the Japanese built engine and seeing what it puts out and where :)
quality here is a little hard to find also.. everyone's attitude is "the muffler shop down the road can knock me up an exhaust with extractors for 650 bucks mate with a high flow cat... then when i tell em if i make one its going to be atleast double and then some they quickly run away lol.. i love when they come back with a mild steel half press bent mig'd together piece of junk that sounds like a tractor with no exhaust.. dags hanging off are free, not to mention the $35 "high flow" cat lmao. a proper decen't high flow stainless cat is around $400 alone. anyway. sometimes chequebooks are handy!
CMF_kovert.k11
» CMF Member
up to taking care of the interior: had a major **** fight tracking down the defi exhaust temp, intake manifold pressure and tacho gauges - defi was apparently affected quite badly by the disasters in japan, and advance cr gauges are being discontinued by defi (60mm cr tacho will be as rare as rocking horse **** soon)... thankfully managed to track them down, get a triple gauge pod and tmrs is now in the process of installing them. have also purchased a set of RG JTC'N1 7 stage coilovers to use instead of the teins (which will go onto the daily drive). cam cover was still at the painters last i heard, but we are getting close to a conclusion - famous last words...
CMF_kovert.k11
» CMF Member
we've been waiting on some custom leads for the ignition coils to be made up... after many weeks and an impatient wait, they are ready.
i also got a titanium exhaust system which requires some dicking around to fit it seems; and there is also a nismo mechanical LSD to install in the 31V box.. there will be some more pics of the build shortly - stay tuned...
CMF_SSUK
» CMF Member
Cool. That's a valid reminder......I have to actually do the same! Best get an order into Magnecor eh ;)
Ti exhaust, wow sounds mega. What's the weight saving over a comparable stainless system? Will be interesting to see how it sounds too, as the Honda's I have seen with them sound a bit crazy. We have to work with a 98dBA noise limit measured at 0.5m from the tailpipe at 45deg angle, at 2/3 maximum rpm. Not sure how that's gonna pan out just yet :-/
I was looking at a Nismo plate type LSD but they are like rocking horse sh*t, one on yahoo at the moment now though but at YEN102,000 I have money better spent elsewhere, plus it will probably be a lot easier to commission Gripper to make one to suit the 31V box.....we'll see after we get things rolling.
We're still waiting for engine parts to arrive, for the shell to be booked in to have some minor work and the engine bay resprayed and also to have the head sent off for some pretty radical upgrades.
Looking forward to the pics, knowing your work this will be one choice motor :) Ours wont be anywhere near as well laid out but it will be interesting to compare things when they're completed, run in and finished mapped.
CMF_SSUK
» CMF Member
Very nice indeed, top job! :)
This build has motivated me to get the engine bay sprayed when the shell goes in for some minor work later this week on the rear sill area, which is a common place for rot here in the UK.
The FCR's sure make the Jenvey's, (which have no more than 3cm maximum between the bulkhead and trumpets), seem huge in comparison.
CMF_Greo
» CMF Member
I think more to the fact he probably isn't running the car on 2cyl might b using different leads while waiting for custom ones? Or not driving it yet.
Little bit of critical thinking next time Hmmm?
Drugs are bad, mmmkay.
Lol
CMF_kovert.k11
» CMF Member
after some dramas with the carbs and fueling, decided to ditch the fcr and get some of this action happening... looking @ you SSUK :)
so if anyone is in the market for a fcr kit, let me know
CMF_SSUK
» CMF Member
Haha, sweet! Matt sent me that very photo yesterday as a matter of fact ;) I had a feeling they may be destined to you but one can never be too sure.
Slightly different to ours, we have the old original design, as attached. There are a few variations but the system length I am sure will be very similar. If so, then cyls 3 & 4 will be damn close to the back bulkhead, (2-3cm). We had the bulkhead cut back to make more room on this build, so we could get an adequate air feed/filtration system in there.
Ours jenveys are a little more fiddly to balance up with the throtle linkages. You'll get a nice 1/2 way house between inboard and outboard injector positioning with those and they'll be a fine addition to an already legendary build.....you wont be dissapointed in adding those into the mix i'm sure :)
Eagrely awaiting the results! How much more is left to do by the way?
We've got heaps on our plate still :/
dang. kovert sent me the pics yesterday. my first reaction is where the hell is that going to fit lol. i can't see it but time will tell lol. car is pretty well finished, just waiting on these quads then its plenty of 1st gear skid action
CMF_SSUK
» CMF Member
"dang. kovert sent me the pics yesterday. my first reaction is where the hell is that going to fit lol. i can't see it but time will tell lol. car is pretty well finished, just waiting on these quads then its plenty of 1st gear skid action
It will be a tight fit I'm sure. The nice thing with the shorter throttlebody units is you have more room to play with horn lengths should you have any problems. Ours are quite short already at 40mm and there's not much scope to change due to the throttlebody elements being 60mm from flange-flange.
I'll be very interested in the numbers once the mappings done :)
CMF_SSUK
» CMF Member
Hahaha! Seems more than one of us needs to be committed then. Only those who own fast cars seem to think people like us are nuts to be putting this much effort into a K11. The usual comment is, 'why don't you sell it and buy something faster'......when they get the response of, 'I already do own something faster' it often throws them off ;)
One can always rock up in one of these if the situation warrants it. In the UK at least, these have way more street cred...
CMF_kovert.k11
» CMF Member
....and now the fun of fitting the quads into the engine bay without modifying the bulkhead begins - first casualty of the process:: the brake booster...removed and replaced with a wilwood master cylinder which will be sporting an AP Racing reservoir...
CMF_kovert.k11
» CMF Member
and for those who thought k11 handling mods couldn't look pimp - custom upper and lower rear control arms..TMRS made a couple of sets for me: this ****box will get some of this luv...
CMF_SSUK
» CMF Member
We turned & welded up an alloy spacer for the OEM master cylinder on our first build. Cost #### all and didn't require any new lines. Braked fine but didn't leave much room for a filter arrangement but it was only done to get the car setup quickly.
How do you plan to rig everything up on the single outlet?
I'm guessing the rules on braking systems are different out there. We'd have to have 2 master cylinders, as the rules state that there must be 2 independent hydraulic circuits of which a single failure cannot result in a total loss of braking.
