K11
I tought I would post a few pictures of my micra see what you guys think
How much was it to get the center bores machined out?Bit of an update I have fitted a set or 14" diamond cut bbs rzs had too get the centre bores machined but they fit well
Very expensive.100 mate £25 per wheel
nah, its the going rate http://www.micra.org.uk/threads/new-hub-studs.58844/#post-648354Very expensive.
Sent from my HTC One using Tapatalk
What !!100 mate £25 per wheel
It really wasn't a problem, file a bit and check against the hub. I found that when checking against the hub, it left an impression I could use as a guide.Didnt fancy doing it myself would rather it be done right and safely and be as accurate as possible
