Sorry if I missed it but what's spec on wheels mate? I saw these on classic mini yesterday, I want them
they are nice aint there a person on ere with them, and dont you have to use wobblies
They are 7x13 et 5, well three of them are one is 0, It appears that the "pair" that I thought I had are not. so thats now on the wide side with a 10mm spacer and an et5 on the narrow side, which has evened out my panhard rod axle shift almost completely. The et5's fit really well on the front too which is a bonus as i thought I was getting 0's :grinning:
Not a fan of those split rim effect superlites, but the gunmetal looks good against the brg.
so is the dish not deeper by a fraction on the 0et?
Annoying immobiliser, I think it might get perminately connected and tucked behind the dash.....
I'd love to replace the front seats, but if I do it will be with 60's style low back buckets, with the rear seat trimmed to match.
These have been posted on here a while a go. Hope it helps
Yeah 5mm to be precise but neither you or I could really tell,
I'm gonna run some spacers when I get arch roller, talking of which are yours scrubbing mark?
I'm liking those pics, got style. I think your right about the rear, just that little bit lower may go a long way looks wise.
Corsa b rear dampers are £22each from fkautomotive iirc.
Wheels Day. I arrived with much less rear arch gap than that, I left with more cash than I arrived.
Loads more here.
so if that stock suspension on that how on earth did you get so low?
i dont understand it my ickle wheels look silly atm
Cars looking apserlutely fantastic mate, and the ride hide i'd say is perfect too, it cuddles into the arches just right, perfectly ballanced, one of my faviourites this one (Y).
Keep up the mint work.
Re-engineered (as HoodedReaper puts it) coils all round, fronts are wired into the cups to prevent them from unseating on drop. On the rear the shocks have been modified, welding mounting plate further down the shaft (essentially shortening it), with a sleeve over the treaded section at the top. Frank does it a lot - its where I got the idea! This prevents the axle dropping too far and allowing the springs to unseat.
This is by no means an ideal solution. The ride is pretty shocking, with the stock shocks not doing a very good job of controlling the bounce of the now much stiffer springs. But it was cheap.
I reckon giving yours a coil off, maybe coil and a half at the front, would be a good starting point, then see how it goes from there. Take a bit at a time, see how it looks then a bit more if nessasray.
I dropped one of my old mercs (long departed) years ago, took so much off the wheel arch was supporting the weight of the car resting on the top of the tyre. Try not to do that. Narrower tyres would probably have made it work, but the car wasn't drivable to get to the tyre fitters.
Thank you sir.
That steering wheel looks pukka, really suits interior IMO
Good news on clocks too
Ever thought of a 1.3 ?
Cheers Mart,
I quite fancy the idea of a high comp 1.3 using a 1.0 block and long stroke internals, breating though bike carbs, or pending the death of a rich relative, ITBs. Maybe even a charged 1L. I think I'd get a perverse satisfaction from making a sub 1000cc car go a well as possible. But tbh I dont have the time for the fannying arround, the space at home for anything too involved and messy or the disposable income for bits, and replacement bits when the ones I bought originaly turn out to be shagged.
Particuarly when the megre funds I do have need to be spent on low back buckets and coilovers with rock hard springs. I might, if I can find one cheap fab up a cherry bomp back box for a bit of rasp, but that is as far as my current performance pretensions stretch.
Will, how does the diameter of the wheel centre hole compare to a spray can lid, or yogurt pot?
.....and I really ought to be putting all of that bunce earnt through making tat into clearing my overdraft. Anybody got £500 going spare?
Shaun thats not an slr, I have one of them as a point and shoot play thing.
Saying that they are exceptionally good and very cheap.
