MAF sensor
No, it measures the mass of air coming in as as compared to a map sensor which measures pressure so also needs a inlet temperature sensor. So the maf sensor already has temperature as a component of its measurement. There's is as far as I know no need for a inlet temperature sensor for the ecu even on a turbo, driver/tuner might be interested though....
I've a dizzy engine. Any idea were the air temp sensor is fitted. Been reading up about tricking the in coming air temp with a resistor to increase the air/fuel ratio. Has anyone tried it.
