Lowering springs
Hi,
How much are you looking to pay? I have a set of 35mm lowering springs brand new in original sealed box.
Or if you want it more lower than 35mm, then matt humphries does 50mm (or 60mm?) lowering springs. His website can be found on google easily - matt humphries oxford. Other good option is to buy 4x suzuki alto pre 2006 rear springs along with corsa b rear shock absorbers, will lower around 50mm all around but you will preferably need a panhard rod if you lower more than 35mm. A pair of corsa shocks is £29 and the 4 suzuki springs will cost you £72 on eBay, links are below.
https://www.ebay.co.uk/itm/Fit-with...943749&hash=item4b1209d111:g:qUsAAOSwWxNYpW70
https://www.ebay.co.uk/itm/Vauxhall...474247?hash=item2f0a222ac7:g:mGkAAOSwhMpZnqww
Hi,
https://www.ebay.co.uk/itm/Fit-with-SUZUKI-ALTO-Rear-Suplex-Coil-Spring-in-Pair-41016/322425180433?fits=Car+Make:Suzuki|Model:Alto|Plat_Gen:HA11&epid=1726943749&hash=item4b1209d111:g:qUsAAOSwWxNYpW70
do you still have urs in box if so how much
