Lowering springs?
No it doesn't, but the springs will be stiffer. Not much necessarily, but they will be.
Probally.
Yeah, I don't reckon you'll feel it much till you start dropping more than 50mm. I'm not speaking from experience however.
I have FK automotive springs on mine at 35mm drop. They are stiffer but not uncomfortably so. I did have to put an adjustable panhard rod on still to bring the axle back in line.
Ah cool thanks :)
No problem. Just a little suggestion if you're going down this route. Spray your panhard rod mounting bolts/nuts with wd40 for a few days before. Especially the drivers side mount. I also slightly loosened the nut. This meant I didn't need to grind off the bush inner sleeve.
To save a fair bit of money you could go for Corsa b coil overs on the front modified for the k11 top mounts to fit, i done this and my cars sittin at 90mm all round. ride is pretty solid aswell!
