Read some of the many current threads on here asking for codes and you will find out what information will be required to get the code (radio serial number) and how to find said serial number............hi, i'm new to this site and trying to get a radio code for a k12 micra, can anyone help?
As I said above, find the serial number and post it on here. If it begins with BP followed by 12 numbers starting with '000' then I wont be able to supply an unlock code, any other 'BP' number so far has been successful, its just the ones with the first three numbers '000' that haven't worked........Hi John, I have read some of your other threads, I have a K12 2010 model micra which has a sat Nav radio however I note on one thread you said your software does not do sat nave radios, is this just for the K13 or dors it include the K12 too?.
Your assistance would be gratefully appreciated, thanks
Thank you John. The serial number is 49110076657. I hope this is the right numberRead some of the many current threads on here asking for codes and you will find out what information will be required to get the code (radio serial number) and how to find said serial number............
No problems, the code that you need is 1441.....oops, wrong serial number. it's BP234746077130
Perhaps this post should be made a 'sticky'?Hi John, hopefully some useful information for you or anyone that is having difficulty in finding the codes for K12 or K13 radios combined with Sat Nav’s
Anyone with a locked radio/SatNav need to type in 0000 3 times which will bring up serial number, device number and date displayed on the screen.
This needs to be photographed along with the log book(as proof of ownership) and your driving licence, then email all the details to
gb@nissan-services.eu
Nissan will send the radio code through by email. Hope this helps
Thanks, I shall try that. i live in Ireland and the agents here want €50 to give me the code !!Hi John, hopefully some useful information for you or anyone that is having difficulty in finding the codes for K12 or K13 radios combined with Sat Nav’s
Hi, either 6307 or 0307 should bring some mobile music back into your lifeneed code for Blaupunkt BP334947326699
NISSAN MM CD-K
E1 022458 ???
can anyone help please. Been locked out for months. Now code screen is back up.
Hi, either 6307 or 0307 should bring some mobile music back into your life......
An ABS wheel sensor fault will be the cause of those problems, one fault, two effects....WWWOOOHHOOOO thanks John_D 6307 worked straight away. Sounds again. ABS light and speedo to go. Poxy Cars, Cheers pal
Yeh, done a lot of reading on it, thanks, but points to module at the moment. Changed both front sensors already. At least we can listen to the stereo while we fix it now.An ABS wheel sensor fault will be the cause of those problems, one fault, two effects....
Hi, try 5052 or 1052.........hi, i'm new to this site and trying to get a radio code for a k12 micra, can anyone help BP5384 7 6537336
Thanks you are the best??Hi, try 5052 or 1052.........
Hi, 1314 would appear to be the number that you need.......Hello, I changed battery in second hand Micra K12 and kindly requesting for code.
Blaupunkt
BP3349 4 7314325
NISSAN MM CD-K
7 643 349 318
e1 022458
Appreciate if you can help me.
Master level! Works for me as before.Hi, 1314 would appear to be the number that you need.......
Sadly even when the later SatNav units are made by BlauPunkt and have a 'BP' serial number (they all start with '000') my software does not give the correct unlock code, so I'm afraid I won't be able to help you.... ☹Hi John,
I have been facing the same issue and I think you’re doing wonderful work in this. My Sat Nav only has a numerical serial number. The details are below and I have attached a pic for reference;
Serial Number: 3138322
Device Number: 7612830023
Can you please let me know if I can get a PIN code for this? I emailed Nissan but they only replied once and didn’t give the pin code.
Code - 4712Hi John,
Hello all,Code - 4712
Hi, try 8183 or 0183....Hi all, the battery on my Nissan micra 2007 went flat and the radio is now requesting the code. Can someone assist on providing the code. I removed the radio and the SN is BP538369457797 (MMR CD-S 7645383318)
Thank you very John, much appreciated???Hi, try 8183 or 0183....
Hi, try 7761 or 1761........Would you please find me the code for my radio Nissan Micra k12
Simples, 1303 :0)Hi please can anyone help me out, radio serial number is BP7383A9041712
Its saying error when I input that:/Simples, 1303 :0)
Just checked it again and that is the only code that my software gives for BP7383A9041712....Its saying error when I input that:/
Sorry I'm an idiot the code is BP7383A9401712, got 2 numbers switched up??Just checked it again and that is the only code that my software gives for BP7383A9041712....
In that case, try 6477 or 0477..... :0)Sorry I'm an idiot the code is BP7383A9401712, got 2 numbers switched up??![]()
Thank you!!! I'll try thatIn that case, try 6477 or 0477..... :0)
