k11 plip key
butta
Kicked in the Member
ive got a 1998 k11 si is this the plip key i should have to open the standard remote central locking?
yes that's the one, it should be 433.92mhz frequencey, which it'll say on the back.
i got a spare one off ebay for £5 delivered. and they are easy to code in aswell, so don't buy re-coding instructions off ebay, i'm sure there's a guide on here somewhere.
here it is here, Fordy gave me these instructions and it worked
1, turn the ignition to on and off 5 times, then leave ignition off but key in barrel still
2, hazards should flash to show coding sequence started
3, hold black button and press red button 3 times
4, hazards should flash to indicate fob coded
5, do same as step 3, to second keyfob
6, hazards should flash to indicate fob coded
7, turn ignition on
8, hazards should flash to show coding sequence completed
9, test both key fobs
you might need to close all the doors and be inside it when doing it as sometimes it wont start the coding sequence,
also you might need to turn the ignition on and off 6 times, i cant remember if its 5 or 6 its a second nature to me so i just do it and not count lol
