k11 newbie, but i got big plans
hi every one thought i'd introduce my self in this section as it will probably be the only one i'll use regularly.
im currently looking for a cheap 1.3 k11, which is going to form a credit crunch/ budget project.
i have several plans and have started collecting some bits already, my most recant purchase is a 4efte (toyota) manifold which will be modified to create a manifold similar to a Mulholland one.
i used this as inspiration
http://www.micra.com.au/community/message.php?messageid=55842
theres also a custom exhaust manifold in the pipe line aswell.
all i need now is a k11
current plan it to use a modified rover 200 manifold and down pipe, i did some quick measurements on my mates micra and the ports have nearly the same spacing, so the flange will be cut off the pipes heated and bent a little to get perfect alignment, then a new flange cut and welded on. or at least thats the plan :-/
haven't got a pic and the manifold is currently buried some when in the garage, google wasnt much help either so here is a link to one on ebay to give you an idea of design
http://cgi.ebay.co.uk/ROVER-200-BUB..._CarParts_SM&hash=item4155a06bd7#ht_688wt_905
Been a long time since I posted, I've been looking for a 1.3 since and its proven rather hard to find one around here, so today I picked this up for the grand sum of £250 :)
Will leave it as a 1.0 then fit a 1.3 engine when I can find one.
