K11 box on to K10 will it fit
New to MSC but spent many years with cherry turbo's.
Our lass has a k10 4 speed and i needed to change the g box and clutch for a 5 speed
Has anybody fitted a k11 on a k10 please
Sorry if i am not explaining things quite right but the k10 mountings are different to the k11
But will k11 mountings fit k10 body? the early k11 gearbox is flush on the mounting face, whereas the k10 face is set back where the mount bolts.
I understand what you say because the cherry turbo gearbox has the same bolt on ring to adjust the pre load bearing.
This box looks the same as K10 4 speed but slightly bigger where the rear mount bolts
yeh, same box eh chezza, the preface 1.0 bracket has 2 short and 1 long bolts (the 2nd short one arrowed) the 1.3 has 2 long and 1 short
Frank thanks for your help mate seems that its been done the other way round ie k10 in to k11 but not k11 box in to k10
maybee i need k10 mounts for a five speed box.
