Instrument pannel broken
Hi, I have a k11 1.5 diesel, does anybody know if I can use a an instrument pannel of a k11 1.0?
I have already tried it, but the temperature thermometer indicates hot water. I don't understand if I have problems with the water temperature or if it indicates hot water because it isnt the proper instrumental pannel.
When my instrumental pannel worked, I had no problem with the water temperature.
Thank you
the sensor on the diesel engine is probably a different rating elisabetta, i would just reset the needle personally
