Ignition Help..
nathan.warren69
Hi Guys,
Im in the middle of trying to hook up my tacho, Ive connected up the power to it but im having trouble connecting the signal cable, I have an 02 plate with coil packs,
Where would you say the best place to connect the wire to is?
I dident have much luck with trying to find it from the ecu or the OBD port so im now going to try the coil however i cannot find where it needs to go, and also where is the distributer? would I be able to connect it to this?
Thanks in advance.
Right so i have 4 coils and they would go back to the distributer right? but where is that?, i think that is where i am going to need to get it from, i could only find 2 small plugs that came out of the ecu..
