How much for starter?
T
Tesla
Guest
How much should I expect to pay for a starter from a scrappy? Are all K10 starters the same? How about K11 or is that different?
The gear/cpg on the starter is worn. flywheel has been reskimmed but the starter needs replacing ideally, I can do this myself, couldn't skim the flywheel myself though.
Cheers,
Chris
Just out of curiosity...is your original problem the same as mine?....
Every now and then (generally when there are by-standers) the starter grinds very loudly / doesn't engage properly when I try to start. Then I have to play with the gears a little in order to get the flywheel to move on slightly before it will engage and start properly.
or is yours just plain dead?
