how long
Hmm, if left in neutral i'd say 10-15 mins. Obv it depends on what the conditions are outside though too!
impossible to tell really,
Weather conditions are a contributing factor as well as the way you drive, higher revs will make the engine heat up quicker.
My CG13 is up to half way on the temp gauge after less than 5 minutes on a normal day driving to work! On 30 and 50 and 60 roads, sticking to low-ish revs until engine is warm.
Weather conditions are a contributing factor as well as the way you drive, higher revs will make the engine heat up quicker..
However if being left in neutral which is what the first post suggests, your driving style won't be relevant :)
