I
iffy
Guest
Can anyone please tell me what this part is and how to fix it?
Many thanks in advance.
It helps to prevent the pin turning turning when you do the nut up as well if you keep the cars weight on it.Have a lil trolley jack handy to push the pin back up into the hub - makes it a bit easier!
Daz
i'm in the same process of replacing my lower arms cos i wrecked me balljoint seals when using the stupid wedge-type balljoint seperators.
problem is that the bolt holdin the arm to the chassis is a pig to get off after 8years. just wont budge with all my effort without fear of roundin the bolt.
shall i just take n angle grinder to it?
