Help
Hi All, My problem I have is a slight squeak when I release the accelerator pedal when changing gear or is it the clutch pedal? Could it be the cables need a little bit of oil on them due to the age of them or do I have to replace them?
Yours Peter0003
Yours Peter0003
Quite often the cause of this annoying squeak is the dry pedal return springs in the pedal box. Try spraying some silicone 'maintenance' spray on them (especially on the end hooks where they go through the pedals and the pedal box frame) to see if it cures it.....
Thanks for Info Peter0003
