Help sluggish
Optispart
Ok my car is being really sluggish at the moment, it was awesome after having the janspeed on but now its really sluggish any suggestions
The car is due for an oil change.
ok well any other ideas aswell as the service seeing as though its had new spark plugs oil change new fuel filter and air filter in september ish, it cant be that bad in this short time can it?
or has all the messing about (manifold, new clutch and box rebuild) make it need a good service?
awww frank i reallly want to be there but i cant im at a wedding im actually gutted!
:( any ideas though matey also at some point you still up for helping me put in 1.3 cams?
yes stock airbox
your plugs should be dark grey (if one or more are a different colour, post a pic)
you should be able to feel 4 distinct compressions (about every 2 ft), if you push the car in 2nd gear on a flat road.
and check the timing with a cheap (powered) strobe light
right ill have a see, cheers for the help really wish i could get to the meet though and have someone with much more experiance and knowledge lol.
as soon as i get hold of some cams ill pm you
