Help please starting to have enought of this thing now
Right I changed the engine to a 1.3 engine put a 4-2-1 manifold on it it ran fine for about an hour and now it's not running right only idles for about two minutes the. Cuts out and when you try and drive everytime you accelerate it misses and takes ages to catch the revs if no one can help its going scrap yard
my failing fuel pump done this for a while, can you hear it on start up? even if you can it may be jerking around till it dies:)
well when i had the 1.0l in it ran ok (other then a failing gearbox) and before i took the 1.3 out that was running ok but now it doesnt seem to wanna run
