Heater vent thing
B
Bennai
Guest
My heater vent has been massacred by a friend, who tried to put my mobile phone holder back in place, the vent is now just a hole. is there neway to take it out and lip the things back in, or just take it out an replace it wiv a new one?
any help appreciated
Yep, its simple. If its the outside two then its slightly more difficult.
Just get a crosshead screwdriver and dissasemble what you see fit.. its a learning experience...
its one of the two in the middle of the dash bored,
u mean i have to take the dash bored out to get to them
....superb
Bennai said:
is this correct, the entire dash has to be removed??
Not if it's one of the centre 2:
* take out the ashtray, there's 2 screws under there
* remove the 2 screws that are above the radio
* pull the centre part out working from the bottom up
* the top part may be a bit stuck (don't use a screwdriver cos it gnarls the
plastic)
* give the surrounding edge part a few thumps from the top and it should
let you pull the front out then
* the air vents can then be removed
it'll only take you 10 mins maximum if you've never done it before. The only thing with some radios, you may need to remove the front plastic part that overlaps the centre dash part (if you've got one that does, you'll see what i mean.
Happy fixing!!
i have a facelift k11, so my airvents are all part of my main dash bored does this mean i have to remove my entire dash or can i jus remove the centre bit
