Headlamp washer switch?
Mika The Finn
Site Supporter
--HELP!--
Could someone who has access to a wiring diagram, please tell me, headlamp washer switch colors/functions?!:unsure::rolleyes:
Micra CD of mine, be at an unknown location!:(
THANK YOU!
1
1
Hi, I have only got the wiriring Schematic for the headlight washer, hope this helps.:)
Terve Mach1!
KIITOS PALJON! = Thank you very much!:)
Just got home from a short trip to eastern Finland.
Multimeter confirmed, green and black in your picture are switch wires that I need.
I assume a blue and other black wires are for switch light...?:rolleyes:
I will use the washer switch to trigger this module ? Wave Wagger 36 Stop-Alert different selectable patterns 4:32 with aux high beams on rear window. For those drivers who think that at speed of 135km/h ~ 85ml/h, it's ok to tailgate behind small car as Micra.
? Wig Wag 36 Pattern Wave Wagger - Headlights Module 10 AMPS Electronic Alternating Heavy Duty Flasher Kit
