Gearbox
Hi
This is going to be hard to describe but anyway. I parked the car after driving it and put it from 3rd into 1st (when the engine is off and clutch in) the gear feels "odd"! The gear "stick" feels very loose and is quite almost a tap sound when it goes into any gear much different from before. I havent done anything out of the ordinary just seems strainge why it feels like this??
Greatful for any help!
Support rubbers? If you look under the car where the gear stick goes into the floor, you will see 2 rubbers or something, check they are not snapped...
Im a k10 person so not sure about the k11 set-up underneth so might not be rubbers...
When they've completely gone, the gearstick will drop through the floor lol. You should get under there and have a look :)
Pretty much explained in my post...:wasntme:
yes apologoies for that.
I havent checked the rubbers yet be the weekend. I've also discovered it likes to crunch the gears. its happened twice now 4th and 2nd gears i pretty sure it not me could, this be connected.
Cheers.
