Fusion CG13DE K11 turbo pistons
Ed
Fusion Motorsport
MSC Founder
Official MSC Trader
Just had the first batch of K11 turbo pistons arrive:
These are priced at £599 a set, and will be cheaper if people are in a group buy or they become popular.
I have designed these with a compression ratio of 8.0:1 and they increase the capacity to 1282.77cc. I can also supply with piston coatings at an additional cost.
These pistons CAN use the standard con-rods. This means however you will be limited to a more moderate power level of approximately 160-200bhp.
For best results use with our uprated con-rods!
I can also do 1.4 pistons and rods. They would be the same price. James T uses these in his engine. These were coated as you can see below:
Yes come with rings and there are headgasket options available, however prices have increased since I did this thread.
Yep can supply. You wont see much change from £1300 odd though. Very roughly £600 pistons and £700 rods depending on spec etc.
U dont do 1.0 forged pistons and are they the same size i was told its the lenth of the conrods that make ir a higher cc dont no wether thats true or not
