front brake upgrade k11
B
BIG SWE
Guest
I need better breaks!! GTI-R calipers are to expensive in Sweden. Is it possible to use any other Nissan calipers/discs? Please help me...:wasntme:
All N14 and N15 calipers and discs fit onto the UK built micra easily.
Just have to make sure the discs are centred in the caliper - as mentioned you do this by changing the position of the caliper with washers. Preferably high tensile or stainless steel washers. NOT mild steel/zincalume washers.
How thick is the washer u suggest?and does it require any bigger size rims?like 15's?coz i m using 14's
naah, 14's arte fine so long as your wheel balancing weights are on the far inner edge of the wheel...(ie towards the inside of the car)....cos mine are on the outer side...and are just 1mm away from the pulsar calipers..lol
very closeeeee..!!!
